Re: My car is haunted!
I dropped the lower part if the dash an checked around the back of the ignition switch for anything out of the ordinary loose connections exposed wires and looked for anything that might be teed into the wiring off the ignition switch and found nothing no random boxes or nothing spliced into the ignition switch from as far as I could see. I will pull the cluster and radio to see of I can find anything it still has the factory radio so it should be easy to spot anything out of the ordinary. Does anyone know the reach of the skreem ring? I would assume it had to be pretty close right?
