Old May 31, 2021 | 07:07 PM
Doc78's Avatar
Doc78
Default Re: Convertible top function
Originally Posted by bmccubbin
I would check the tension cords that are located on each side and under the Top Pads (web straps). I suspect that one or both have broke. The tension cord has a coil spring on the front end, at the front bow frame, and then attaches to the backside of the first cross frame member. I believe the cord is prone to break by the cross frame member.
There's another cable (steel) that runs from the corner of the Front Bow frame to the second cross frame member and has a small coil spring on the back end. This cable runs inside a pocket on the side of the top. This cable also helps to hold the front section up. This cable is not likely to break, but maybe has come unattached from the front bow frame.
Anyone have any pictures that may help with this my SRT does this as well
Also if mine are broken what is the part number and where may I purchase another one?
