Old Jun 1, 2021 | 02:28 PM
Bob0121's Avatar
Bob0121
Default Re: Spoiler has no power and electric seats don’t work.. HELP 😭
Originally Posted by Doc78
CrossfireForum - The Chrysler Crossfire and SRT6 Resource >Technical >TSBs and How-To Articles
I listed the location of how to's and tsb above
I don't know what year your crossfire is so I cant help because the fuses do vary base on year model.(there should be a card on the top you removed that will tell you what the fuse controls).
I see that one of them is the fuse # 9 I mentioned above. The buzzer in these cars go bad and blow the #9 fuse. That is why I asked you to roll the windows down and then open the car from the inside. Note again if buzzer is good be prepared for loud alarm and have others be ready too.
If the lights flash and no sound(or sounds like a cricket on crack, you will know what i mean) buzzer is bad. There is a great thread here on how to replace/repair.
I will have to research what 6 and 7 do. Like I said there are really great people with way more knowledge than me on here.
I've had a bunch of this stuff happen to my own but I have a SRT so no wing issues for mine.( I have worked on my buddies wing) His was the position sensor went bad. Id still unplug the two that go to the spoiler and check for corrosion. If there is clean it with electrical cleaner and check for water in the trunk as mentioned above on the passengers side trunk area beside the molded black foam.
I've had the power seat issue. Mine just came unplugged under the drivers seat while moving something got stuck and popped off the connector but I learned quick where the relay was.
If it is quiet and you put your ear up to the driver side under dash and try to move the seat forward and back( don't hurt yourself) if you hear a click you know the relay is working and the problem is elsewhere.
I will try to help more when I find out what 6 and 7 fuse control.
Thanks for reply and information
I’ve just tried what you said with the alarm so with the window down I locked the car using fob and then put my arm in and open the door using the door handle from inside and nothing happened apart from door and boot unlocking no buzzer or anything noise
my car is a 2004 coupe
as you can see from the picture I’ve attached above showing the blown fuses it’s the number 10 and 5 fuses
tomorrow I will undo the cover under steering wheel and check the sensor/relay if it makes a clicking noise when the seat button is pressed
As it’s 2 fuse numbers 5 and 10 I’m guessing one is for seat electrics and other for spoiler?
