Old Sep 16, 2023 | 05:19 PM
Rickjeff280's Avatar
Rickjeff280
Default Re: Beeping Alarm over 80 mph
Originally Posted by Crossfireone
Your beeping over 75 mph is usually accidently turned on after your car is in for service & had a DRBIII hooked into the system. It falls under the (customer preference) portion of the DRBIII & is either on or turned off by the tech. Theres no speed choice avail. other than on at 75 mph or not on at all. The only way to remove your beep is to have a DRBIII hooked up again & the choice turned off. Simple procedure but costly if you have to take it to someone who has this tool. We live in diff. parts of the country or I would be glad to turn it off for you. Hope this helps.
Crossfireone
I am having this beeping issue also I don't have the set but I have the convertible if I drop my top it will beep for about 15 seconds and if the drive is interrupted it starts all over I hit 80 and it beeps like crazy. What setting is it that I can change on the computer.
