letmethink
Is it possible the RCM would have any effect on the cooling fan not operating, or is that limited to the Fan Control Module and 50 fuse ?
So I would check the actual plug from the fan to the fan control module once you verify the fuse I just went through something similar, the connections inside that plug where actually lose and pushed out of the socket. I ended up just bypassing that plug completely and hard wiring my fan kicked right on. Good test is to turn your ac to 1 the fan should start spinning at low rpm.
