True story
Old Sep 14, 2013 | 07:59 PM
Sandy's Avatar
Default True story
I woke up at 4am to go to the Car 'Cruise In' in San Antonio. My tire pressure warning light had been on for 3 days. Couldn't get it to turn off! I jumped in the Crossfire and hit the road. Tire Pressure light still on, but the BAS/ESP warning light came on too! Reset it. Came back on. Reset it 2 more times, and it still came back on! And, my cruise control was out! And I realized I was an hour early! So I went and ate breakfast, and then went to the 'Cruise In'. Xalidin jiggled the fuse for the cruise control. And I reset the BAS/ESP warning light for the 4th time! As I was leaving, I found that the cruise control was fixed. Thanks, John! And the tire pressure warning light was out. And the BAS/ESP light was out! And it stayed off...so far.
The moral of the story: Go to car GTG's and heal your Crossfire! I think it has something to do with testosterone. But, it definitely works!
Old Sep 15, 2013 | 12:20 AM
JesseJamessrt6's Avatar
Default Re: True story
I need to be going to all of them then.
Old Sep 16, 2013 | 11:12 AM
Sandy's Avatar
We've been missing you, Jesse. The orthotics are working great, and you, sir, are a saint!
Turnouts have been good, lately! 2nd Saturdays at Lowe's at the Rim (8 - 10)
Old Sep 16, 2013 | 11:39 AM
rayth's Avatar
way to be persistent with trying to reset that light and hoping it was fixed!
Old Sep 16, 2013 | 01:00 PM
Good to hear! I will have to ry and sneak out to hang out with you guys soon.
Old Sep 16, 2013 | 01:13 PM
Thirteendog's Avatar
Did the car feel like it lost power steering when the esp/ABS light came on?
Old Sep 18, 2013 | 11:14 AM
Sandy's Avatar
No, it did not seem to lose power steering. But, today (4 days later) both the BAS/ESP and low tire pressure warning lights came back on! I might actually have to address the issues, instead of only going to GTG's!
re: BAS/ESP - My brakes are OK, so it probably has to do with stability control. My mechanic looked at it when the warning light was off and said the computer had no record of the warning at all.
re: Low tire pressure warning light - Tire pressure is perfect. I got new wheels, but they took the TPMS off my old wheels. But, that does seem to be when the problem started. I run about 33 front and 34 rear - about 1 psi above recommended.
I STILL recommend going to GTG's although I can no longer state that your car will be 'healed' by such actions.
Old Sep 18, 2013 | 11:21 AM
Your ESP module controls the ABS, but it's odd you didn't get an error code. When that light comes on remember that ESP is automatically shut off and ABS is no longer working. I don't remember if your ESP module controls your steering, but I don't think it does.
Old Sep 18, 2013 | 11:29 AM
Sandy's Avatar
I reset it each time, but I am getting tired of resetting it! I will have to get serious about this!
Old Sep 18, 2013 | 11:49 AM
Bill F's Avatar
Sandy, you put your old TPMS on with your new wheels, did you put new batteries on the sensors? When I put new wheels on, I also put new sensors on, once I had the correct sensors programmed by the Chrysler Dealership, I've had no problems.
Old Sep 18, 2013 | 08:59 PM
Mrmiata's Avatar
ABS/ESP errors report through the DRBIII interface (DAS).. I'm guessing your mechanic just hooked up a regular "check engine" DRBII code checker. Mine have been lit up and "non functioning" for a year now with no brake issues.. And burnouts don't require a "disable" button first.. LOL.
Old Sep 18, 2013 | 09:38 PM
Sandy's Avatar
Thanks. I will check it out Saturday morning.
Old Sep 19, 2013 | 10:43 AM
Xalidin's Avatar
I would also go ahead and maybe look at replacing the fuse. They are pretty cheap, you just might need a pair of needlenose pliers to get it out. Just make sure you put a new one in with the same rating.. Couldn't hurt and for under a buck.. worth a shot..
Old Sep 19, 2013 | 02:14 PM
sounds like corrosion at the fuse box or a weak fuse connection. I usually from time to time pull and clean them making sure they all are snug fitting when I put them back in
srtmodder
Aug 23, 2017 08:28 PM
MiamiTVR
Other Cars Etc
15
Oct 3, 2015 09:02 PM
maxcichon
Sep 30, 2015 11:38 AM
triplmmm
Sep 24, 2015 12:12 AM
Valk
Sep 17, 2015 11:43 AM
