CrossfireForum - The Chrysler Crossfire and SRT6 Resource (https://www.crossfireforum.org/forum/)
-   All Crossfires (https://www.crossfireforum.org/forum/all-crossfires/)
-   -   2006 Crossfire Won't Start (https://www.crossfireforum.org/forum/all-crossfires/68830-2006-crossfire-wont-start.html)
catuttle Aug 12, 2014 02:40 PM
My check engine light was on and I am not sure what the code was associated with it. I am totally NOT mechanically inclined. I cranked it at work and it cut right back off. I thought maybe I just cranked it too fast so tried again and it worked. Got home and the next time I tried to crank it, same thing except this time it stopped altogether and just the dash lit up.
I am being told by the mechanic that the Engine Management Relay needed to be replaced and that the old one burned up my Pulse Module. Is this something that is possible? Are there any questions I can ask them to make sure there wasn't a smaller/cheaper fix?:confused:
AlG Aug 12, 2014 02:45 PM
Re: 2006 Crossfire Won't Start
If it's still trying to start it could be the crankshaft position sensor. Also could be the relay control module. These are known problems that might cause your car to act this way. Do a search on the forum. You'll find much info.
ala_xfire Aug 12, 2014 02:45 PM
Most likely cold solder joints on the RCM ( Relay Control Module )
Search for "Mystery No Start" and you'll find more than you probably wanted to know.
catuttle Aug 12, 2014 02:51 PM
What is the difference in all the "relay" and "module" names?
ala_xfire Aug 12, 2014 02:59 PM
The RCM is a circuit board with mounted relays.
It is in the box by the battery closest to the engine.
It has about 5 harness plugs connecting it.
Remove the negative battery cable before pulling it out and unplugging it.
It's not easy, but the plastic cover comes off and you can inspect the solder points with a strong magnifying glass.
Lately there have been several that had open relay coils.
DJ ( tighed1 ) can figure all this out for you, all you have to do is send it to him along with some beer money.
catuttle Aug 12, 2014 03:15 PM
Thanks for the breakdown and explanation, it helps my limited understanding. I just got off the phone with the mechanic. Their diagnosis is that my entire Relay Control Module was burned up by the pulse module, something to do with pulling too much current. I guess I am trying to just figure out if this is a feasible explanation and diagnosis.
Thank you for your patience and answers.
ala_xfire Aug 12, 2014 03:20 PM
No, it is not a feasible diagnostic.
The RCM and pulse module are like bad neighbors, they have nothing to do with each other.
The pulse module ( located in the under hood fuse box ) is controlled by the ignition key.
The ignition key tells the pulse module to do it's thing, which is engaging the starter and timing how long that should occur.
The design is to prevent burning up the starter motor.
tighed1 Aug 13, 2014 12:50 AM
1. So when you turn the key does the engine crank (turn over, spin whatever you wanta call it)?
2. Or do you get no crank but all other electrical stuff work?
If 2 then follow the RCM REPAIR link for instructions to fix it.
Welcome to the Forum!
n2racing2 Aug 13, 2014 08:50 AM
Hi tighed1,
My engine cranks....but won't start...so mine is number 1. What is the problem associated with that?
ala_xfire Aug 13, 2014 08:57 AM
Originally Posted by n2racing2 (Post 808110)
Hi tighed1,
1. CPS ( Crankshaft Position Sensor )
2. no fuel :
a. are you out of gas ?
b. is there fuel pressure at the rail test point ?
c. can you hear the fuel pump run when you move the key to just before start ?
3. no spark. - hopefully it is not this as that gets complicated.
Padgett Aug 13, 2014 09:17 AM
Classic "cranks but does not run". First thing I usually do is triage: pour about 1/2 ounce of fuel directly into the intake, button up, and try to start. If it runs then dies it is a fuel problem. If nada then probably a spark issue. (weasle words: have a good fire extinguisher handy.)
Once that is done I pull out the right set of gauges.
Have only three possibilities: fuel, fire, mechanical & of the three, a mechanical failure without sound effects is the least likely. (Crank sensor is an electrical problem)
n2racing2 Aug 16, 2014 01:47 PM
Problem fixed. It was the crankshaft sensor....thanks for the input guys!
n2racing2 Aug 16, 2014 04:15 PM
Well....thought it was fixed. Went for a test run and seemed fine...and then just went dead. Wiggled connector...got it to start and started home. Died 3 times on me on the way home...had to adjust connector each time to restart the car and made it home. Think the connector is going bad. That seem possible?
GraphiteGhost Aug 16, 2014 05:06 PM
?? Did you buy a BOSCH sensor? I read in another post the others are smaller connectors then the BOSCH and they are a little loose in the connector. With our cars, there is a saying 'Go Bosch or Go Home' so if you bought a sensor from your local auto parts store you could be walking home. Just saying...
n2racing2 Aug 16, 2014 06:46 PM
Hmmmm....was not Bosch.....may have to buy one and see. Symptoms now are....starts....runs to about 3000 to 3500 rpm and then dies. Will restart but problem repeats itself.
power90801 Aug 21, 2014 12:12 AM
I would love to send my RCM to you for the repair and horn fix, what's the first step sir? Besides removal of course...
tighed1 Aug 21, 2014 07:32 AM
Step #1 - Email me.
tighed1 at hotmail.com
n2racing2 Aug 30, 2014 11:09 AM
Update: replaced CPS with a Bosch CPS.....problem solved. Seems there is some truth to go Bosch or go home! Thanks for help guys!
whoosh Aug 30, 2014 12:43 PM
It more like.. go Bosch or don't make it home.
onehundred80 Aug 30, 2014 01:39 PM
Actually it's 'Go Bosch or walk home'.:cool:
© 2026 MH Sub I, LLC dba Internet Brands
