Need help with Manuel top
Old May 11, 2015 | 10:33 PM
cgrover1973's Avatar
Default Need help with Manuel top
Looking for help. 2005 srt the top light just blinks and won't work either way. I have researched it and manually worked it both ways and it still won't work.
Any help would be great. Thanks
Old May 13, 2015 | 11:16 AM
chuK_138's Avatar
Default Re: Need help with Manuel top
You may want to check the hydraulic fluid reservoir to make sure you have enough "juice" in there. One of our Florida people just fixed the same issue by topping off the reservoir. Hopefully it's just that.
Old May 15, 2015 | 02:56 PM
Goldwing's Avatar
It may be too obvious, but is the partition in the trunk secure in the slots. If it was knocked loose, the light blinks and the car beeps but the top goes no where.
Old May 15, 2015 | 03:13 PM
Also the switch in the trunk latch assembly, it is in series with the divider switch, BOTH must be closed.
Old May 17, 2015 | 09:46 PM
Thanks for the reply. I will check it and let you know.
Osusannah
Feb 12, 2024 01:49 PM
Valk
Jul 12, 2021 09:49 PM
Mackel
Oct 16, 2015 09:03 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
