Limp mode confusion
I recently got the limp mode nightmare. I have an 05 N/A Roadster with 60k on the clock. It was a hot day, and I stopped for two minutes. I backed out into the street and punched it pretty good, only to find that it will not shift. I've read a lot of threads, and only get more and more confused. "Trans connector plug leak,...connector plate,...trans fluid low,...TCM contacts bad.
I had a check engine light for a while, but it went off by itself before I could put the scanner on. I've tried disconnecting the battery for a day, ..no good. I guess my question is,.."where to start, If limp mode can be caused by so many things. I have not seen any drips on the garage floor, so I assume the fluid is ok. No dipstick for that anyhow. Thanx in advance for any assistance. |
Re: Limp mode confusion
I had to have mine towed to a connector plate repair shop (dealer).
Under warranty, fortunately. |
Re: Limp mode confusion, UPDATE
(Post 846056)
Under warranty, fortunately. I took it to an inde MB shop near me. Lots of weird codes. My battery was weak, so we installed a new one. No help. I removed, and checked the TCM. All connector pins looked fine. No oil anywhere I'll post my progress here for others who may have this issue. I miss driving her. |
Re: Limp mode confusion, update
Ok, after reading MANY threads, here, and on MB World, my inde mechanic, and I decided to change out the connector plate, and plug housing, tranny filter, and fluid. We checked all the solenoids for continuity, they were fine. We noticed one of the solenoid connections on the plate was a bit loose. We took the car out, and it did not shift right till we shut it off, and tried again. It seems perfect now. His scanner said we may need to drive it, shut it off, and try it again. That worked. Hope this helps someone with the limp mode problem.
OK, another update. The above did not cure the problem. Now we're going to look for a chafed, or mouse chewed wire. Failing that I'm sending off the TCM to have it checked out, and repaired. This is getting old.
Originally Posted by Abaton6
(Post 848495)
Bill T.:confused: |
Originally Posted by Bill T.
(Post 848503)
Boy do I feel your pain. I am somewhat in the same spot as you are. So far I have changed out the external connecter, it was leaking and quite wet from fluid. The car has been OK to a point so far. I did have a couple of HARD shifts and one very minor limp mode. Did not need to restart. I plan on a wait and see approach for the time being. I do have a new Conductor Plate ready to be put in. (next step) Time will tell. What bothers me is this car only has 36,500+ miles on it.
I did check codes again and had a P0715 pending. It did reset. Like I said, time will tell. Bill T.:confused: All codes posted here to save for future reference >> Diagnostic Trouble Code (DTC) List |
Originally Posted by VALK
(Post 848508)
P0715 Input/Turbine Speed Sensor Circuit Malfunction
All codes posted here to save for future reference >> Diagnostic Trouble Code (DTC) List Thanx Valk. I'm going to talk to the dealer tomorrow. I don't know what else to do. I'll report back. |
(Post 848736)
What were they? Codes give people clues to the problem. |
(Post 848508)
All codes posted here to save for future reference >> Diagnostic Trouble Code (DTC) List Had the car out today, ran sweet until almost home. Had a couple of hard shifts. Didn't check for codes. That "Input/Turbine Speed Sensor Circuit Malfunction" tells me that it's time to swap out the Conductor Plate and check the connector again. The Conductor Plate I bought came with another (new) connector. I will have my transmission guy change out both and check and make sure that no fluid wicked up the harness. Bill T.:( |
(Post 848738)
Weird codes?
What were they? Codes give people clues to the problem. PO715, and MANY others. I bring it in to a Dealer on Wed. When I spoke to the service manager today, he didn't blink when I said Crossfire. Good sign. |
OK, another update, The dealer found a bad torque converter solenoid. That and the diagnostics were $536. BUT that did not fix the problem. They traced it to the TCM. That's going to be $695. I should get it back next week. What a cluster intercourse this has been! Total will be $1650.00. And I thought I was getting MB quality.
(Post 849359)
(Post 849373)
Like I said before, I feel your pain. I haven't driven my XF but about 3 miles since the Conductor Plate was changed out, along with the connector. What other codes did you find, other than the P0715? That information would be VERY helpful to the folks here on the forum.:confused:
(Post 849375)
When I pick up the car, and empty my wallet next week, I'll ask for a list of the codes.
Bill T. |
Final update,...l hope. One of the solenoid coils was out of spec for ohms resistance. Had to be replaced. Also, the first TCM they installed was bad. The second was ok, but they needed to contact Chrysler to download the correct programming. So, after all this time and trouble, the total is $1800.00. I sincerely hope this crap doesn't happen to you. Seriously thinking of selling in the spring. But I'll probably fall in love again.
(Post 849359)
Good luck. Oh I even was able to get a free Billet grille for my 05! All because they....... oh........ we love our cars! |
Originally Posted by Flamenco2005
(Post 876438)
Next time you have issues go to Crossfire Market Place on Facebook. So many experienced Crossfire owners with free advice and help at no Cost!
Originally Posted by dinasrt
(Post 876459)
LOL... If you believe there are more "experienced Crossfire owners" at your Market Place; I submit that you are sorely delusional. :p
God Bless you any ways. |
Hi
Just some information that might be useful to others with transmission problems. 1. If your transmission goes into limp home mode and you repair it by replacing the conductor plate, you still need to use Mercedes Star Xentry/Das to clear the fault codes from the TCU. Otherwise the TCU still thinks the fault is present even though you've fixed the transmission. 2. If you need to replace your TCU, then just get a used one from the wreckers. The TCU contains information about the transmission gear ratios and the diff ratio. The SRT6 TCU therefore contains different coding to the NA TCU, so get the correct one. If you can't find a Crossfire TCU, then you can use Star Xentry/Das to recode any EGS52 TCU (from a Mercedes) to work. You can copy the code from your existing TCU to the replacement one, or code it directly from Star Xentry/Das. The code to use for the NA TCU is "AF0Y", the code for the SRT6 is "BH52". |
