2005 crossfire best brake fluid to use.
Old Sep 24, 2015 | 05:01 AM
Jackobo's Avatar
Default 2005 crossfire best brake fluid to use.
Sorry new to this just bought an 05 crossfire and love it just doing a full service on it can anyone recommend best break fluid to use many thanks Jack.
Old Sep 24, 2015 | 09:59 AM
Default Re: 2005 crossfire best break fluid to use.
From the Service Manual;
The brake fluid used in this vehicle must conform to DOT 4 specifications and SAE J1703 standards. No other type
of brake fluid is recommended or approved for usage in the vehicle brake system. Use only MoparT brake fluid or
an equivalent from a tightly sealed container.
Obviously you do not have to use the Mopar fluid though.
I used MOTUL RBF 600.
Old Sep 24, 2015 | 10:01 AM
It is a good idea to use one which is a different color and then you can see when the new fluid comes out of the caliper.
Old Sep 24, 2015 | 12:58 PM
Jackobo's Avatar
Thanks a lot will do that would you recommend a engine flush before a service , can't wait to get it out on the road
Old Sep 24, 2015 | 07:08 PM
Is that an oil or a coolant flush?
If oil then I'd say put in new oil and change it after 1,000 miles if you think the car has not been looked after.
If coolant I'd say do it with distilled water, getting out as much of the old coolant as possible. CLICK
Or run hose water through the block for a while. CLICK
Old Sep 24, 2015 | 07:51 PM
Jackobo's Avatar
Brilliant hanks for the advice not a lot on the crossfire over in the UK rare to see but best car on the road 🙌, got all major service history but just like the make sure it's always gonna be running to the best it can be, anything that I should look out for that I might need to know about ie common faults cheers. Jack
Old Sep 24, 2015 | 10:21 PM
pioneer4x4's Avatar
My advice to every new person is read all the stickies in each group. You can learn a ton in an evening. And download all of the downloadable manuals and guides.
reiji
Jul 19, 2015 07:40 PM
TWOFAST
Jun 25, 2015 03:50 PM
kiskasky1
Jun 18, 2015 06:21 AM
MJPowers
Jun 8, 2015 02:34 AM
WindRestrictor
Jun 1, 2015 02:31 PM
