How I do wrinkle paint n photos
Painting wrinkle is similar to regular painting but heat is the issue for getting consistant sized wrinkles and a pleasing pattern.
First prep the work as normal, clean is the deal. Spray one coat on light to medium - not heavy. Depending on temp wait 5 - 10 minutes and spray again using a different pattern - start out from the opposite side or end.
Wait 5 - 10 minutes and do a third light coat and then place it in the sun or wash it with a heat lamp. as the wrinkles form keep moving the heat lamp or rotate in the sun. Cool weather is really not a good time to do this unless its in a heat maintained building and then you must use the heat lamp to touch up areas that are slow to form.
Enjoy the photos and my other albums, WDY
https://www.crossfireforum.org/g/album/9975010
Re: How I do wrinkle paint n photos
ala_xfire
18
03-15-2018 09:54 PM
grip grip
28
06-05-2014 12:52 PM
ala_xfire
15
07-02-2013 08:12 AM
MAYAman
07-28-2006 09:10 AM
