Compress Springs or just go for it?
RESOLVED: Compress Springs or just go for it?
Going to be changing out my front lower control arms today. The guy that is going to be assisting me says that I do not need to compress the springs before removing them since we do not have the tool for it. This seems a bit unsafe, but I do not know just how much tension these will be under. We will have the car on a body lift, so the wheels will be hanging down, so they will not be fully compressed at least. Then the idea is to use a "High Position Jack Stand" like pictured below to support the control arm as I take the bolts off and then slowly lower it down by unscrewing the jack stand adjustment. Someone else mentioned chaining the spring to the frame to make sure that it does not shoot out. lol
If this is as unsafe as it sounds, I do not mind buying a spring compressor from Advanced Auto or Auto Zone today before I go if they are not over $100 or so. Please feel free to suggest a product if you have one you like.
Thanks,
Thanks,
Re: Compress Springs or just go for it?
Those springs do not come down directly vertical but move in an arch. The tall jack you plan on using WILL NOT take any force to the sides. It is used only for straight down force. What you are attempting is really dangerous. Borrow a spring compressor from an auto parts store if you can find the correct type, or buy one. It is a lot less expensive than one trip to the hospital.
I've removed/installed my springs (front and rear) without and later on, with a compressor. Where you save or lose your sanity is getting it back together. IF you have a helper you can get it together once you figure out how to tug/pull and in which direction without one. If your only doing it once in your lifetime, it's worth the effort to do it without. If you believe the springs will be coming out multiple times buy the correct spring compressor off ebay or amazon and breeze through the work.
Les
Les
The bandages, plaster and splints does not allow him to use any means of answering you. You’ll have to wait until he recuperates.
It is best to realize before you play with a spring that if it gets loose it will expend all the energy it took to get it to its current compressed state in an instant and you do not want to be near it when it does.
ryan48
10-22-2010 09:58 PM
imported_mightyjlr
08-08-2003 03:04 AM
