Headlight Water Drain Tube
Old Aug 23, 2024 | 04:01 PM
Nelson G's Avatar
Default Headlight Water Drain Tube
I was poking around the ECS website when I came across these Headlight Water Drain Tubes and I decided to purchase them. They fit inside of the plastic tube that is at the back of our passenger-side headlight. It took a little bit to slip them into the tube but they fit well. If you look at the tube it has two square holes on either side to let moisture out. I placed them so the holes were parallel to the ground. I did put a little bit of crazy glue on them so they would not work themselves out. (overkill, I know)
Here is the link: https://www.ecstuning.com/b-genuine-...e/91163125902/
Davem17
Sep 15, 2023 05:40 PM
208james@gmail.com
Jul 1, 2023 01:34 PM
burg1989
Mar 31, 2021 10:37 AM
maxime75us
Nov 4, 2013 11:14 AM
nox1s
Aug 11, 2009 11:16 AM
