Part Number List
Old Apr 30, 2006 | 10:12 AM
danimal's Avatar
Default Part Number List
For those interested, the Crossfire Parts List can be downloaded and saved from:
http://www.2ndgendurango.com/extras/06zh.pdf
Old Apr 30, 2006 | 01:59 PM
HDDP's Avatar
Default Re: Part Number List
Thanks Dan: I'm sure this will help alot of the DIY members...
Old Apr 30, 2006 | 02:29 PM
danimal's Avatar
Derek, I know you found some bad part numbers while redoing your brakes. When you get a chance, will you let us know if the correct numbers are there now...or still wrong. This list was published in Dec '05 and is for the '06 xfire. Just curious on accuracy. I have looked up a few parts that I have bought and it seems to be right on.
Old Apr 30, 2006 | 03:10 PM
HDDP's Avatar
The brake parts were from the SRT6 that I installed on the Limited. I don't see the SRT6 parts listed in this catalog, so I can't compare. They had listed the wrong caliper adapter part #'s for the SRT6 and showed the Limited caliper adapter... I know it was finally resolved through chryslerpartsdirect.com
Old Apr 30, 2006 | 03:45 PM
danimal's Avatar
Okay, thanks.
Old May 1, 2006 | 07:46 PM
aptiva's Avatar
I knew someone would come up with the parts list sooner or later.
Thanks a lot, great help. Bob
Old May 8, 2006 | 11:33 PM
Turk's Avatar
Thanks for the parts list Dan. Greatly appreciated, i am sure i will need it sooner or later and i hope later than sooner. Thanks again, TURK.
Old May 11, 2006 | 09:57 AM
ichon's Avatar
Thanks for the info. Greatly appreciated.
Old May 12, 2006 | 01:15 PM
chxf's Avatar
Hi Danimal
Thanks for the great link! Very interesting.
Cheers
Old Aug 30, 2006 | 03:18 PM
MI1XFIRE's Avatar
Just found the link from an other post. Thank you very much to Dan for posting this, It will be very useful when dealing with the Chrysler Parts guys or should I have said not having to wait for them to find the part numbers.
A++++++++++++
Old Aug 30, 2006 | 03:28 PM
Steenport567's Avatar
How do you save it? Windows Xp.
Old Aug 30, 2006 | 03:56 PM
danimal's Avatar
It is an Adobe .pdf file. Save it as a .pdf file wherever you wish and then open it in Adobe Reader if you don't have Adobe Acrobat.
Old Aug 30, 2006 | 04:35 PM
dynamicS's Avatar
After going thru the parts list pdf. I noticed that (EGX) is the code for normally aspirate vehicles, and code (EGZ) is for the SRT6.
Just thought I'd mention this little fact.
srt frnt spring; 5142 010AA.
sway bar srt, looks like the same one as on Limited XF.
shocks srt; 5135 484AA and 5142 011AA.
srt axle; 5159 990AA.
srt rear rotors, 5135 475AA ;rear backing plate 5135 478AA and 5135 479AA.
too many other numbers to list for rear brakes, find the rest yourself.
catalytic converter srt, 5135 432AA.
CATALYTIC CONVERTER DELETE FOR EXPORT MODELS!!!! right (5101 597AA) left (5101 598AA) YES!!!
EGZ muffler # 5135 436AA.
rear srt egz shock, 5161 528AB.
rear spring, 5102 312AA.
rear sway bar looks to be the same as limited XF.
please review my part numbers for accuracy...
Old Aug 30, 2006 | 08:43 PM
marauderroy's Avatar
Smile Re: Part Number List
Thanks for the parts list. I'm having trouble getting the "right stuff" from my dealer.
Old Sep 2, 2006 | 11:09 AM
stlouistrucker's Avatar
Great document. I have a question. Page one shows that "Country of Origin" for Germany is a "4". That agrees with other lists that I have seen. I have also seen Germany is a "W". My 2005 LTD roadster has a "1" for the first digit. That is for USA. Do I have a problem? I thought that my car was built in Germany.
Old Sep 3, 2006 | 04:44 PM
dynamicS's Avatar
Found some more srt parts while doing a search for HDDP's camshaft research. figured I repost this here.
Cooling, Intercooler, Intercooler, Intercooler - w/supercharger 1 $210.00 $156.24 $0.00 $156.24
Cooling, Intercooler, Intercooler, Insulator, Insulator - w/supercharger 1 $2.70 $1.98 $0.00 $1.98
Cooling, Intercooler, Bracket, Bracket - w/supercharger 1 $28.50 $21.08 $0.00 $21.08
Cooling, Intercooler, Connector hose, Connector hose - w/supercharger 1 $3.05 $2.26 $0.00 $2.26
Cooling, Intercooler, Outer hose, Insulator, Insulator - w/supercharger 1 $7.50 $5.58 $0.00 $5.58
Cooling, Intercooler, Air baffle, Air baffle - w/supercharger 1 $67.00 $49.60 $0.00 $49.60
Cooling, Intercooler, Intercooler, Bracket, Bracket Right - w/supercharger 1 $8.00 $5.95 $0.00 $5.95
Cooling, Intercooler, Pump, Pump - w/supercharger 1 $308.00 $228.16 $0.00 $228.16
Cooling, Intercooler, Clamp, Clamp - w/supercharger 1 $6.50 $4.84 $0.00 $4.84
Cooling, Intercooler, Outer hose, Clamp, Upper - w/supercharger 1 $2.00 $1.49 $0.00 $1.49
Cooling, Intercooler, Intercooler, Bracket, Bracket Left - w/supercharger 1 $8.00 $5.95 $0.00 $5.95
Cooling, Intercooler, Pump, Buffer, Buffer - w/supercharger 1 $4.40 $3.22 $0.00 $3.22
Cooling, Intercooler, Radiator hose, Radiator hose - w/supercharger 1 $13.00 $9.61 $0.00 $9.61
Cooling, Intercooler, Outer hose, Outer hose - w/supercharger 1 $40.00 $29.76 $0.00 $29.76
Cooling, Intercooler, Outer hose, Clamp, Lower - w/supercharger 1 $1.20 $0.87 $0.00 $0.87
Cooling, Belts and pulleys, Serpentine belt, w/supercharger, w/supercharger 1 $55.00 $40.92 $0.00 $40.92
Engine, Supercharger and components, Air duct, Air duct Right - w/supercharger 1 $227.19 $169.04 $0.00 $169.04
Engine, Supercharger and components, Air duct, Air duct Left - w/supercharger 1 $227.19 $169.04 $0.00 $169.04
Engine, Supercharger and components, Supercharger, Supercharger - w/supercharger 1 $2,140.00 $1,587.20 $0.00 $1,587.20
Engine, Supercharger and components, Tensioner, Tensioner - w/supercharger 1 $52.00 $38.44 $0.00 $38.44
Engine, Engine parts, Camshaft gear, Camshaft gear - w/supercharger 1 $61.00 $45.26 $0.00 $45.26
Engine, Engine parts, Crankshaft seal, Crankshaft seal - w/supercharger 2 $8.28 $6.98 $0.00 $13.96
Front suspension, Brake components, Caliper, Caliper Right - w/supercharger 1 $474.00 $352.16 $0.00 $352.16
Front suspension, Brake components, Caliper, Caliper Left - w/supercharger 1 $474.00 $352.16 $0.00 $352.16
Front suspension, Brake components, Rotor, Rotor Back - w/supercharger 2 $92.00 $68.20 $0.00 $136.40
Engine, Engine parts, Crankshaft damper, Bolt - w/supercharger 1 $3.20 $2.36 $0.00 $2.36
Exhaust system, Manifold, Exhaust manifold, Exhaust manifold Right - w/supercharger 1 $380.00 $282.72 $0.00 $282.72
Exhaust system, Manifold, Exhaust manifold, Exhaust manifold Left - w/supercharger 1 $340.00 $252.96 $0.00 $252.96
Exhaust system, Manifold, Exhaust manifold, Gasket, Gasket - w/supercharger 2 $2.20 $1.61 $0.00 $1.61
Total: $3,970.82
Old Sep 3, 2006 | 05:58 PM
HDDP's Avatar
That's only a partial list of the parts you need to upgrade... And still you'll need to deal with the computer... It would be a 3 month DIY in the garage project...
Old Sep 4, 2006 | 06:24 AM
danimal's Avatar
Look here for the VIN decoder:
https://www.crossfireforum.org/forum...ght=VIN+NUMBER
I think Derek (HDDP) listed it in his post.
Old Sep 4, 2006 | 09:29 AM
acrispy1's Avatar
Thanks Dan this will be real helpful.
Old Feb 26, 2010 | 11:15 PM
xodus52's Avatar
I realize this thread is very old and was wondering if anyone has a new working link to an updated parts list? ....or perhaps could upload their existing pdf? much appreciated!
