Tire Pressure Light
Old Apr 6, 2007 | 07:05 PM
TFS04Coupe's Avatar
Default Tire Pressure Light
Went to custom wheels and couldn't get the tire air pressure sensors to fit them. Anybody have any info on possibly disabling the tire pressure light on the dash??? Thanks.
TFS
Old Apr 6, 2007 | 08:04 PM
AMGLover's Avatar
Default Re: Tire Pressure Light
Deleted Message
Old Apr 6, 2007 | 08:36 PM
Maxwell's Avatar
just disconnect the indicator lamp from its socket in the dash.
p.s. don't forget to check your tire pressure once a week, unless you like buying new rims.
Old Apr 10, 2007 | 12:46 AM
HDDP's Avatar
You won't have any other associated issues aside from the light on the dash. I can't believe they couldn't fit the sensor in the wheel... HACKS !!!
Here's what you do... have the morons dismount the tires again, at their own expense !!! Find any place inside the wheel that the TP monitor will stick with heavy double sided tape or super glue. The TP monitor has a barometer and transmitter, so as long as they are inside the tires/wheels, they will measure the pressure and transmit the info. You can even cut off the valve if you want...
Old Apr 10, 2007 | 11:48 PM
stryfox's Avatar
If you decide to just put out the light.
Put some electrical tape on it just like the VCR clocks back in the 80's.
Old Apr 11, 2007 | 12:34 AM
VCR? What's that?
Old Apr 11, 2007 | 11:18 AM
xfire2005's Avatar
Does that apply to both Beta and VHS?
Kodebuster
Nov 5, 2020 04:06 PM
PimpDaddy
Sep 29, 2016 11:55 PM
Bifftws
Racing
Jul 28, 2015 05:31 PM
axnguyen
Jul 21, 2015 11:41 AM
Blackout317
Jul 7, 2015 08:38 PM
