running power wire
Old May 30, 2007 | 10:09 AM
tashspop's Avatar
Default running power wire
where is a good place to run the power wire from the battery into the cabin of my car. i'll be using 4 awg wire and when i pull up the carpet in the passenger foot area, i found a really big surprise with all the computer stuff there.
Old May 30, 2007 | 10:27 AM
blacklimitedcoupe's Avatar
Default Re: running power wire
Under the passenger foot area is actually the factory amplifier to the stereo, not the computer. Although the battery is on the passenger side, you could run it along the fire wall to the driver's side where there is a rubber plug. You can remove that plug, drill a hole in it the size you need, and then re-insert it. Or, you could drill a hole in the firewall on the passenger side and use a plastic grommet that usually comes with 4gauge wire if you purchased it for a stereo installation.
Kodebuster
Nov 5, 2020 04:06 PM
jhansen
21
Feb 15, 2017 04:26 PM
gp1200x
Dec 6, 2015 12:59 PM
BrenLW
Aug 5, 2015 04:53 AM
axnguyen
Jul 21, 2015 11:41 AM
