Full install
Old Nov 2, 2007 | 10:27 PM
palexfire's Avatar
Default Full install
i finally have all the components for my system i will instal tommorow sat. 2 kenwood amps 1 1,000 watt 1 800 watt. an infinity component system and 1 10 inch sub and a brand new jvc kd-avx11 indash with 2.7 lcd dvd player (only thing that fits) i will have pictures of the before during and after. so 1,800 watts in total more than enough for the crossfire so tune in!!!
Old Nov 3, 2007 | 09:14 PM
palexfire's Avatar
Default Re: Full install
ok so its done! installed with a lil help of my bro inlaw. took us like 4 hours. step by step what i did.
disconect the battery. then run the power cable from the positive in the battery through the fire wall. by the fuse box on the driver side is a hole you can use. then take out the stock radio install the new one. thats easy just read. my set up allows 3 different sets of rca wires. one for the sub one for the front speakers and one for the rear speakers. the sub rca are pluged into a 2 chanel amp that i bridged for 1,000 watts. then the other 2 rca went into the amp as line a and line b. line a the front speakers line b the rear. run speaker wires from line b into the rear speakers. now run line a intoo the cross over then the cross over to tweeters and the front speakers. same with the sub. i forgot to mention ground your amp and connect the power and the wire from the stereo that tells the amp to turn on. most of the ime will be spent on running wires and taking off intirior parts. other than that not to bad sounds great. 1,800 watts makes the hair in my nose tingle! now thats loud! sounds great nice crisp clear. wanna give thanx to everyone on here who helped me out. i didnt know anything about car sounds and now i sound like a pro. best site on the web!...! will have pics in a few min...
Old Nov 5, 2007 | 03:32 PM
palexfire's Avatar
ok so here are the pics
Old Nov 5, 2007 | 04:52 PM
radmanly's Avatar
Looks great! Thanks for the report.
Old Nov 5, 2007 | 04:53 PM
marauderroy's Avatar
Looks like you did a good job. Are you still running the stock door speakers and stock (behind seats) subs. ? You have any rattles ? I noticed you did not put ant dyna mat on the doors etc.
Old Nov 6, 2007 | 02:45 PM
palexfire's Avatar
the rear subs i replaced with 2 way infinity speakers. they sound great great highs and mids and bass out of this world. no dynamat. thats because i get little to no base from the doors just highs and mids. and the rear give off bass but not enough to make it rattle, the sub is the only thing that gives bass. i noticed i need a pic of the actual radio.
Old Nov 6, 2007 | 03:04 PM
palexfire's Avatar
here go some pics.
xfireohio
Jul 20, 2020 12:03 AM
da pink
Aug 12, 2015 05:20 PM
Aug 5, 2015 12:52 PM
MAXIMUM
Aug 4, 2015 11:04 PM
Jul 29, 2015 06:13 PM
