Harness for radio
Old Dec 27, 2007 | 08:38 AM
Scott_lmtd's Avatar
Default Harness for radio
I see most folks are using the Scoshe VW01B harness for the stereo swap, of course the red and yellow wire swap, but has anyone used the Metra harness and which one? I called a few shops they inidcate the metra 1784 and I had one shop tell me that metra has a new one for the crossfire, a 709401?
Has anyone used the Metra harness and if so please let me know which one and if any mod's were needed like the Scoshe.
Thanks
Scott
Old Dec 27, 2007 | 08:43 AM
Maxwell's Avatar
Default Re: Harness for radio
this is all I can find http://4x4icon.com/crossfire/pioneer_tuner/index.htm
, try doing a SEARCh on the forum, there is more info here than we think
Old Dec 27, 2007 | 09:07 AM
Scott_lmtd's Avatar
Thanks for the info. Been searching for a while, here and other sites. Can't find anything on the Metra connectors, some say use the 1784 or 1786 and the new one that popped up 70-9401 has even less info.
Old Dec 28, 2009 | 09:10 AM
timcarl44's Avatar
Ok guys, I just finished the install on my girlfriends 04 crossfire. I thought I would post this info as I found it very useful.
First, the Scosche harness is NOT a direct plug and play. You have to remove some wires. Look closely at the front of the harness and you will see that the pins have a small flange that you can squeeze with needle nose pliers. You have to figure out what slot is what, you should be holding the harness and looking at the pins with the clips on the right. The top row is (left to right)
A8,A6,A4,A2.
A7,A5,A3,A1 Harness clips
B8,B6,B4,B2 should be on
B7,B5,B3,B1 this side.
Ok so now that you know what is where, lets start removing wires. A1,A3,B2,B8,B1,B7 need to be removed.
Now on your radio harness you will need to find your speaker wires. Take the front right and rear right and twist the positive and negatives together, essentially making four wires into to. You will have to do this for the left side as well.
Ok so pay no attention to color wires, more importantly is the position on the harness.
Start with A4 this is constant power.
A7 is 12v ignition
A8 is ground. Please read your instructions from the radio to find the corresponding wires on your harness.
A6 is the illumination, turns on the lights when your headlights turn on.
A2 and A5 will now be twisted together and connected to the remote wire on the radio harness.
That should conclude all the wires in the A block.
The remaining wires are your left right positive and negatives, you will need to figure out what is what.
I hope this helps.
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
Sterling57
Apr 11, 2016 06:11 PM
smokey847
Nov 12, 2015 11:54 PM
brandoni
Sep 30, 2015 07:48 PM
Selbyl
Sep 26, 2015 04:15 AM
