New Radio Installed!
Old Mar 29, 2008 | 09:43 AM
Dal05xfire's Avatar
Smile New Radio Installed!
Installed in a 2005 Base Coupe with 6 speed manual.
Pioneer DEH-P5000UB Head unit
Pioneer EX-P10HD Pioneer external HD tuner
I purchased the above through Crutchfield after reading several threads here and finding out that it is a very easy install. Wired the harness using the great how to post that can be found in this forum. There is no need to bypass anything just wire it up. The only change is swaping the power wires as described in the how to post. If you go with the HD option be aware that space is tight and you will have to do some careful tucking of wires to make it all fit but it will fit. I pulled the center faceplate with controls off and gave myself more room to place the HD box and wiring. I didn't need the extention wire for ANT. I ran the USB cable up through the shift boot area and it looks fine. I can pull out cable or push it back in as needed and I think it looks very clean. Did all the wiring inside the house took it out and in 20 minutes tops had it in and playing.
It will take me longer to read the instructions for the head unit and HD tuner than it took to put it in.
If you are planning on buying from Crutchfield here is a referral code that gets a $20 break for you and for me. Handy since I'm planning on adding some speakers soon. I think it's good for 3 people so first come first served.
Code: p82ry-pvcix-sipqy
Old Mar 30, 2008 | 02:59 PM
crossfirefun's Avatar
Default Re: New Radio Installed!
Sounds good, now we need pics!
Old Mar 30, 2008 | 04:45 PM
CoupeGirl's Avatar
pics.......
PNA
Nov 12, 2020 04:44 PM
MiamiTVR
Jan 30, 2016 02:15 PM
smokey847
Nov 12, 2015 11:54 PM
steps
Sep 3, 2015 07:24 PM
MAXIMUM
Aug 4, 2015 11:04 PM
