Spark Plugs
Old Jul 19, 2008 | 03:10 PM
everrion's Avatar
Default Spark Plugs
Here's my problem:
(rough idling) While idling, engine will heel over every so often.
(decreased MPG) Have noticed a significant decrease in MPG in the past few weeks. I thought it was due to ethonal being added to the gas, but after further investivation no one adds ethonal here in Southern Louisiana.
Oil, oil filter and sir filter were changed 3,500 miles ago.
Check air filter, looks clean.
Have not checked fuel filter, I don't think that's the issue with 28,000 miles on the vehicle (It's not like I'm adding farm diesel to my car.)
I'm afraid to take it to the shop because there are no dependable automachanics here. Every wants $.
I think it might be the spark plugs. What do you think? If advice on which spark plugs to choose?
'05 roadster
Old Jul 19, 2008 | 04:43 PM
MMZ_TimeLord's Avatar
Default Re: Spark Plugs
Stock plugs are suposed to be good for 100,000 miles.
I changed my plugs and wires at just under 50,000 to Mangacor wires and Torque Master plugs.
I would say check where you got fuel last... might be bad gas.
Old Jul 19, 2008 | 04:53 PM
chuck65's Avatar
TimeLord is correct. The original plugs should be OK at 28,000 miles. They're designed to go 100,000 miles. If one or more of the plugs is fouled, it's probably not the plugs fault, you may have another problem. If you do replace the plugs, I would suggest putting in the same brand and heat range as the originals unless you are racing, and then you would want to go to a colder running plug. waldig just posted a very useful thread on changing plugs. Good Luck https://www.crossfireforum.org/forum...ht=spark+plugs
Old Aug 9, 2008 | 01:57 AM
ejavis1's Avatar
My 05 Raodster was idleing rough too! I changed plugs to Pulstar and it solved the problem i only have 23,000 on my car!
Old Aug 9, 2008 | 03:21 AM
chuck65's Avatar
If you had a bad spark plug, replacing it with any brand plug would have solved the problem temporarily. If there is something causing the plug to foul out, such as a leaking valve stem seal, it will foul out the Pulstar also over time.
Did you do it yourself or did a mechanic change the plugs? Where the plugs that came out original or did someone before you put in the wrong heat range? What was the condition of the plugs when they were removed? It's possible that one of the wires was not attached correctly and now after replacing the plugs, it's back where it should be.
I had customers that swore that when they replaced their spark plugs with another brand it ran better. It's mostly perceived. If it did run better it's because a plug or two was fouled and any brand would have made it run better.
Let us know how you make out. Good Luck
Old Oct 9, 2008 | 06:38 PM
rommel7645's Avatar
Default Re: Spark Plugs 2004 crossfire
hey guys just question for u , i was just curious about how to replace my spark plug , i know that i have skinny hand but stiil its hard to pull the wire plug and remove it . thanks
Old Oct 10, 2008 | 03:42 AM
waldig's Avatar
Talking Re: Spark Plugs
I wrote up a posting on how to change the plugs, look my postings for details, there is a really simple thought or two in there which can make BIG differences. Enjoy, WOODY
Old Oct 10, 2008 | 04:17 AM
mrphotoman's Avatar
You can use an 18mm or a 19mm open end wrench to pop them off, it works really well.
Valk
Jun 22, 2025 09:15 PM
Sterling57
Apr 11, 2016 06:11 PM
Sep 28, 2015 07:40 PM
atdavis2
Sep 21, 2015 01:25 PM
Wisconsinfdcrossfire
Sep 20, 2015 10:04 PM
