Need front fascia access panel
Old Dec 12, 2008 | 01:54 PM
bogieman's Avatar
Default Need front fascia access panel
Can anyone point me in the direction of an internet business that I may can order this panel from? Bought car used and missed (because car is so darn low to the ground) that something must have rolled under the front drivers side and busted the black plastic panel that shields the fog lights from underneath the car. Believe it is called the left front fascia access panel? Mine is unrepairable and it may be causing some noise at higher speeds.
Have not been able to find one online, and I really hate to order one from the dealer($$$).
thanks for any help
Old Dec 12, 2008 | 02:00 PM
Default Re: Need front fascia access panel
5097959AA is driver's side, 5097958AA is passenger side....sowardcustoms can order them for you w/ a 20% discount...just PM him....good luck...Chrysler is the only one that has them...they fall out if you don't keep an eye on them..
after reading your post again...not sure...these are the access doors to the fog lts if this is what you are missing....
Old Dec 13, 2008 | 05:46 AM
bogieman's Avatar
What I need is the black plastic cover that bolts to the underside of the drivers side, just forward of the wheel well. It actually bolts to the underside of the fender. Something must have kicked up and taken it out. Its just flapping in the breeze. I not sure that we are talking about the same thing.
It was kinda hard to see real well when your nose is pressing against the cover under the car. I was replacing the steering damper when I noticed it.
thanks for the reply
Old Dec 13, 2008 | 08:01 AM
MikeR's Avatar
You are not. The little door fits on the piece that you want to buy. I just had mine off doing the LET HE install. What you want is the splash shield. See the below for the pic and part numbers.
Download the part manual from here......
https://www.crossfireforum.org/forum...ad.php?t=13875
and you can find all your part numbers.
MikeR
File Type: doc
Old Dec 13, 2008 | 12:46 PM
bogieman's Avatar
Thanks Mike, that is exactly what I needed.
PNA
Nov 12, 2020 04:44 PM
psuperti
Feb 24, 2020 10:26 AM
MiamiTVR
Jan 30, 2016 02:15 PM
rocketrage
Oct 7, 2015 05:00 PM
maxcichon
Sep 4, 2015 12:50 PM
