New Radio!!!
Old Jan 10, 2009 | 12:37 AM
shreker's Avatar
Default New Radio!!!
if i get a new radio will still be able to use the infinity stereo?????or what do i need
Old Jan 10, 2009 | 07:25 PM
07bluezx14's Avatar
Default Re: New Radio!!!
I had my poineer 6000 installed, and they just used a harness behind the headunit. Just like any other radio, same thing on my 97 cobra with the mach 460 stero(amps). Shouldn't have an issue. The harness they ued for my car was for a jetta or something, and two of the wires are backwards, and everytime I shut off the car I would lose the memory in my headunit, so you might want to ask about that. I think it was a red and a yellow wire that were changed. chris
Old Jan 10, 2009 | 10:41 PM
shreker's Avatar
what i mean is will the factory amp and everything else work???
Old Jan 10, 2009 | 11:58 PM
07bluezx14's Avatar
I believe everything will work. I have a base model coupe
Old Jan 11, 2009 | 10:29 AM
maxcichon's Avatar
I installed a Pioneer head unit with an HD adaptor and it uses a wiring harness that connects direct to the factory amp and runs it just fine. If yuo buy from Crutchfield, they provide the harness as part of the purchase and along with the very nice instructions, it makes it a truely Plug-n-Play install.
The instructions include a very clear note about swapping the 2 wires. (12VDC on all the time and 12VDC switched).
The upgraded headunit made a remarkable difference/improvement to the sound system!
Old Jan 11, 2009 | 12:57 PM
ppro's Avatar
You can run your new head unit through the factory amp and speakers if you want. As has been stated, Crutchfield provides the necessary harness plug (Schosche VW-1B) that you can buy anywhere for $7 and good instructions for the Crossfire (which you can get here for free). You will pay list price for their admittedly superb customer service and one-stop shopping.
Alternatively, you can buy the harness plug and read through the web site here. Basically you wire the harness plug onto the wires coming out of your new head unit (possibly swapping the red and yellow wires) and plug it into the factory socket in the dash and you're good to go.
If you decide to add speakers, sub-woofers, amps, etc. (I did) you can leave the factory connections (I did) and use the additional plugs on your new head unit (if you have any) to run outputs to amps, speakers, subs, remote power-on to amps and subs.
See my write-up for a Pioneer DEH-P980BT with several IP-Bus components added, as well as additional rear speakers and sub.
More here (click)...
Old Jan 12, 2009 | 05:29 PM
07bluezx14's Avatar
I wish the new poineer, had more functions like the older versions. I find myself having to use the remote to change settings. But I'll get used to it. chris
Old Jan 12, 2009 | 06:42 PM
ppro's Avatar
I'm not sure I have that problem. All the functions on mine come into play through the **** circled in blue, or the List, Source, Disp, Phone, or EQ button.
When you push in on the main ****, you have Function, Entertainment, or Audio. Each is context-sensitive, which means the options beneath are applicable to the currently selected source. I have a number of options there for each of my sources (AM/FM, CD, iPod, XM, HD Radio, USB, BT Audio, Phone, Aux (my "guest" 3.5mm stereo plug for passenger device). There's room for one more AUX device, TV, and a CD-Changer. I can't imagine having more options.
I haven't taken my remote out of the case except to make sure it worked!
One thing I figured out was that if you switch to Phone, it pauses whatever you're listing to which makes it easy to pause something even if you don't want to really use the phone - and it pauses when a call comes it, so that's nice.
The menus do get a little deep so often cannot mess with them while rolling. I kind of miss the old EQ's that used to be bolted to the dash with the 16 little sliders - it was easier to adjust without looking at them than the display version that this unit has - but at least it has it!
Old Jan 12, 2009 | 07:40 PM
07bluezx14's Avatar
it just seemed much easier to access functions a couple of years ago. I have stuck with pioneer for three headunits, and this one definately takes more patients. I would also like to mention the cd that comes with it instead of a manual. guess you have to learn with the times. chris
Old Jan 12, 2009 | 07:50 PM
Veloce's Avatar
How does that thing show the Chyrsler Crossfire logo?
BTW, I've been to your website. Very informative as well as intimidating.
Old Jan 13, 2009 | 10:31 AM
patpur's Avatar
Senior Member/Moderator
That is pretty neat. I can download screens to my Alpine, I'd like to know where that came from as well.
Pat
Old Jan 13, 2009 | 03:43 PM
ppro's Avatar
I made the graphic and then uploaded it to the head unit through the CD player interface they have set up for this Pioneer Head unit. I just followed the instructions that came with the head unit and scaled the image to the right proportions to fit the screen size as be as large as possible.
What part of the site is intimidating? Curious to know in case there's a way to make it better.
Old Jan 13, 2009 | 05:12 PM
Veloce's Avatar
intimidating only in a sense that I marvel at all you've done. It's a compliment!
Can you make the *.jpg available?
Old Jan 13, 2009 | 05:58 PM
ppro's Avatar
Thanks. I looked for the image but could not put my hands on it right this minute. I will see if I can find it.
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
Sterling57
Apr 11, 2016 06:11 PM
smokey847
Nov 12, 2015 11:54 PM
brandoni
Sep 30, 2015 07:48 PM
Selbyl
Sep 26, 2015 04:15 AM
