L.E.D. Bulbs
Old Apr 11, 2009 | 03:31 PM
palexfire1's Avatar
Default L.E.D. Bulbs
so my lic plate bulbs burnt out so i replaced with led bulbs they looks so much better i will post pics tonight so u can see them better atnight has anyone else replaced any with led???????
Old Apr 11, 2009 | 04:03 PM
nox1s's Avatar
Default Re: L.E.D Bulbs
yes, lots of us have.
did you install resistors to prevent the bulb out light from coming on?
Old Apr 11, 2009 | 04:08 PM
palexfire1's Avatar
no i didnt because i didnt know i had to... ok so whats a resistor where can i get it and how much?
Old Apr 15, 2009 | 09:18 PM
Cydetrak's Avatar
Same here. How do I install it to get the bulb out waring light off?
Just installed some LED's and the light came on.
Any help would be great!!
Thanks
Old Apr 15, 2009 | 10:08 PM
Squirrel Crusher's Avatar
Did the bulb out light actually come on for a tag light? I could understand if it was some type of brake,park or signal bulb. What bulb part number did you install for your tag light? I would like to also change out the front turning signal bulbs with LED's but I'm not chopping and splicing my wires for a resistor. Squirrel Crusher
Old Apr 16, 2009 | 05:58 AM
Cydetrak's Avatar
Mine were the parking corner lights in the headlights. I read another post where the guy just put electircal tape to cover the bulb sensor light.......is there any other way?
A mechanic friend of mine said if all the parking lights were changed to LED the circuit might correct itself? anyone know if this is true?
Old Apr 16, 2009 | 06:05 AM
maxcichon's Avatar
http://www.ledlight.com/led-light-lo...er-20-ohm.aspx
You will want the 20 OHM units.
Old Apr 16, 2009 | 09:42 AM
I was just waiting for Max to chime in with the right answer... and the link to purchase. You are the lighting guru.
Now if I can only figure out how to change the glovebox light.....
Old Apr 16, 2009 | 04:30 PM
palexfire1's Avatar
ok so i tried to install the ressistor i dont know what the heck went wrong long story short by the time i was done i couldnt get my dash or center console to light up took me half an hour to find the right fuse to change because youd be surprised how many different fuses have something to do with the instrument cluster i quit im living with the stupid bulb out indicator.!!!!
Old Apr 16, 2009 | 04:59 PM
nox1s's Avatar
electrical tape is your friend
2004_
Jul 9, 2025 12:39 AM
gp1200x
Dec 6, 2015 12:59 PM
xfClifford
27
Nov 10, 2015 10:08 PM
toob
Sep 26, 2015 11:44 AM
maxcichon
Sep 4, 2015 12:50 PM
