Help!!!
Old May 19, 2009 | 06:03 PM
svtcobra's Avatar
Banned
Default Help!!!
I js purchased a new needswings cai but wen i try to take out the mass airflow meter the
screws where stripped wat can i do to get the stripped screws out
Old May 19, 2009 | 06:49 PM
Sean760's Avatar
Default Re: Help!!!!!!!!!!!
Contact Rob I believe his application doesnt require having a star 5 point torq's. (which I basically grinded a slit in the head of it so I could unscrew it with a flat head since no one sold a 5 point torq's anywhere nearby.)
Old May 19, 2009 | 07:21 PM
GDC-SRT's Avatar
Default
Sears sells reverse direction drill bit type extractors that work well.
You set your drill in reverse, on low speed for more torque.
Hope you get em out!
Old May 19, 2009 | 07:41 PM
parawxman's Avatar
Is the head of the bolt stripped or is it the threads in the hole?
Old May 19, 2009 | 09:13 PM
bluecoupe's Avatar
Try a pair of needle nose vise grips, failing that a BFH!
Old May 21, 2009 | 11:45 AM
ChuckNorris's Avatar
Default Re: Help!!!
Vice grips easily removed mine than I replaced with standard hardware
