Where can I find a hot wire (12V) easily?
Old May 21, 2009 | 09:30 PM
user 8202's Avatar
Banned
Default Where can I find a hot wire (12V) easily?
I am searching for a 12V source that is available without the ignition on. In other words, a wire or connection that I can tap into to retrieve 12V for powering an external device. The radio is one source if by removing it I should be able to find a hot wire back there. How easy is it to remove the radio?
Power in the cargo area would be ideal and what I'm really looking for.
TIA
Old May 22, 2009 | 12:43 AM
Default Re: Where can I find a hot wire (12V) easily?
Not near the cargo area but the fuse panel on the left end of the dash inside the drivers door has some live circuits.
Old May 22, 2009 | 06:54 AM
user 8202's Avatar
Banned
Yea, I was there last night checking it out. All the sources are switched unfortunately. Still looking for a hot wire regardless if the key is in the ignition or not. After looking at the service manual, their are two sensor devices hidden behind the trim, found under the rear hatch lock. These sensors are security sensors that will require full time power. I will look into that option when I get a chance next.
Old May 22, 2009 | 11:10 AM
I recall when hard wiring my radar detector into that fuse panel finding a few contacts that were live with the car off and the key out.
I was looking for a circuit that was only live with the key on and found one I could use.
Well anyway I hope you find what you need to complete the install.
Gary
Old May 22, 2009 | 11:21 AM
user 8202's Avatar
Banned
I'll take a second look. I was in there with a probe looking for voltage, but confess I didn't check every fuse location. Reading the list on the inside panel, it is mostly headlamps and taillamps including brakes if I remember, all needing the key to operate. If you recall finding some hot points, It's worth a second look as the location will work for me.
Cheers;
northwest_crossfire
May 30, 2016 05:19 PM
BrenLW
Aug 5, 2015 04:53 AM
Jul 29, 2015 06:13 PM
Ralph289
Jul 26, 2015 12:52 PM
waldig
Jul 20, 2015 08:10 AM
