starting problems in 05 crossfire roadster
Old Jul 18, 2009 | 02:17 PM
sue.d's Avatar
Default starting problems in 05 crossfire roadster
I have a 05 crossfire with approxiimately 30,000 miles. I am the original owner, have maintained the car. This has happened twice now. Car does not start. Everything works just will not start. first time I was at my regular garage to drop off a car. Turned mine off and went back to start and nothing,Nada, ZILCH! Flatbedded to dealer and when it got there the car was fine.. No problems started right up. OK so they changed the clutch safety switch. Now one year later the same thing. Go out to start the car and nothing. Also tried to pop clutch to start. Nothing. Towed to dealer and got the car of truck and stared right up. Can't duplicate complaint. all i was told was when it happens agin to call, but if they cannot send out a mechanic to check it whats the point. I think the giggling around on the flatbed must do something. The car is off warrantee but if this is an ongoing problem should this be covered. Now that I have had this happen two time. Anybody else
Old Jul 18, 2009 | 03:45 PM
wild srt6's Avatar
Default Re: starting problems in 05 crossfire roadster
Had this issue and it turned out to be a bad starter motor. I would first replace the batteries in the remotes as the car needs to see the transponder in the key, if the batteries are weak it can cause a no start issue.
ttosh
Jun 12, 2015 08:25 PM
Ron H
Jun 12, 2015 02:56 PM
Franc Rauscher
Jun 7, 2015 10:51 PM
DarcyD
Jun 2, 2015 10:02 PM
DarcyD
Jun 1, 2015 07:39 PM
