Downshifting into neutral
Old Oct 29, 2009 | 03:02 PM
TX_xfire's Avatar
Default Downshifting into neutral
I test drove an srt yesterday. I pulled off the lot and accelerated to about 40mph then braked for the light and the car would downshift real hard from 2nd into neutral while the car was still in drive. I had to put it into neutral or park then back to drive for it to go. I thought that was strange but it happened almost everytime I slowed down. The only way it stopped was I finally used the shifter to manually change gears and take it back. Does this sound like a transmission problem or was I doing something wrong? It's been awhile since I had an automatic but last time I checked D was for drive.
Old Oct 29, 2009 | 03:42 PM
tighed1's Avatar
Default Re: Downshifting into neutral
Might be low on tranny fluid. You brake and the fluid goes to the front of the pan. Filter sucks air, trans goes into neutral to protect itself.
That's my first guess.
Old Oct 29, 2009 | 04:04 PM
TX_xfire's Avatar
Possibly, the check engine light was on. Oh...and no it wasn't a BLACK one.
Old Oct 29, 2009 | 08:01 PM
billvp's Avatar
wow, was this on a dealership used car?
Old Oct 29, 2009 | 08:13 PM
GDC-SRT's Avatar
Probably has or had the dreaded transmission leak. It is not a matter of will it leak, more when will it leak. The fix is below....Thank you Waldig.
https://www.crossfireforum.org/forum...-ta-daaaa.html
needfreetime
Aug 9, 2024 09:28 AM
minimayhem
17
Jan 19, 2016 02:10 PM
jimf
19
Oct 19, 2015 04:05 PM
rmcdaniel12
Jul 21, 2015 11:35 PM
ApocMan
Oct 9, 2007 11:32 PM
