ECU Reset
Old Dec 17, 2009 | 07:09 PM
crossfire2006's Avatar
Default ECU Reset
does anyone know how to reset the ECU without disconnecting the battery?
i do not want to disconnect the batter because i do not have the code for the stock radio anymore
Old Dec 17, 2009 | 07:18 PM
robby363's Avatar
Default Re: ECU Reset
Why do you want to reset it..
Old Dec 17, 2009 | 07:20 PM
i did a tune-up and just want to reset the ECU back to stock setting.
so it can relearn from there
MikeR's Avatar
Disconnecting the battery wont hurt the radio either.... you may loose your programmed stations.... I dont remember...(dang memory anyway)..
Old Dec 17, 2009 | 07:22 PM
cool i thought if i disconnect the batter would lock the radio until i input the factory code
kind of like my Civic Si.
Old Dec 17, 2009 | 07:25 PM
MikeR's Avatar
You also dont have to disconnect the battery to do that.....
1. Turn key to ON (not start) position
2. Press gas pedal to floor(feel little button go click)
3. Hold for 5 seconds
4. Keep pedal to floor and turn key to off
5. Release gas pedal
6. Wait 2 minutes and then start car.
DONE!
Old Dec 17, 2009 | 07:26 PM
that just resets the FSS correct not the ECU
robby363's Avatar
You can do a throttle reset without disconnecting the battery. That's all the ecu is going to relearn unless you have a check engine light for a code.
Old Dec 17, 2009 | 07:28 PM
MikeR's Avatar
That is the throttle reset... not the FSS reset....
i thought if i reset the ECU it would set the ignition time back to stock setting
this is the main reason why i want to do this and the tune up was a good start too
i want to see the ignition change on the scangaugeII
Old Dec 17, 2009 | 07:33 PM
robby363's Avatar
Here's how to reset the FSS
The counter can also be reset by any individual after the indicated service has been performed.
Perform the following to reset the counter:
1. Turn the ignition key to the ON/RUN position.
2. Within one second press the ****/button to the left of the display twice.
3. The present status for days remaining or distance traveled is displayed. Within ten seconds turn the key to
OFF.
4. Press and hold the ****/button to the left of the display, while turning the key to ON/RUN again. The present
status for days remaining or distance traveled is displayed once more. Continue to hold the ****/button to the left
of the display.
5. Release the ****/button to the left of the display. After approximately ten seconds, a tone sounds and the
display shows 7,000 miles (11,000 km) for approximately ten seconds.
If the FSS counter was inadvertently reset, the counter must be reset.
The message is displayed for approximately ten seconds when turning the key to the ON/RUN position, or while
driving when reaching the service warning threshold. It can be cancelled manually by pressing the ****/button to
Once the suggested term has passed, the message, plus either the symbol for Service A or the symbol for Service
B preceded by a “–” (minus symbol) blinks for approximately thirty seconds and a tone sounds every time when
turning the key to the ON/RUN position.
The FSS display can also be called up for approximately ten seconds with the display illuminated by pressing the
****/button to the left of the display twice within one second.
Note: When disconnecting the battery for one or more days at a time, such days will not be counted. Any
such days not counted by the FSS can be added.
The interval between services is determined by the type of vehicle operation. Driving at extreme speeds, and cold
starts combined with short distance driving in which the engine does not reach normal operating temperature,
reduce the interval between services.
Old Dec 17, 2009 | 07:34 PM
Thanks Robby but i am not looking to reset my FSS just the ECU
i guess i will just disconnect the battery
Old Dec 17, 2009 | 07:52 PM
the ecu will relearn everything,, (your driving habits) and every thing you want it to in 100 or so miles. jim
Old Dec 17, 2009 | 10:49 PM
thanks Jim. i disconnected the battery tonight and will reconnect it tomorrow morning
so the relearning process will begin
Old Dec 7, 2014 | 12:59 PM
Futureknows's Avatar
edit: found answered elsewhere
SparkieSRT6
Jan 11, 2016 10:49 PM
stelrz1
Sep 21, 2015 11:18 AM
tritongreen
Sep 18, 2015 07:32 AM
RacerXofFL
Sep 15, 2015 05:00 PM
sk8erjosh09
Sep 4, 2015 09:24 PM
