High Miles and ohh so dirty
Old Apr 21, 2010 | 05:21 PM
Beaner's Avatar
Default High Miles and ohh so dirty
I removed my throttlebody today to replace it with a larger one and I was discusted how dirty it was. The amount of crap flowing into the intake is CrAzY. I have not had it off before but I have wiped it out a little when I put on my CAI when I first installed it last year. I will be looking into a catch can or something very similar very soon. I took some pictures
Old Apr 21, 2010 | 05:55 PM
Default Re: High Miles and ohh so dirty
Beaner your the man, now you have the part in your hand, do you think it is possible to bore out the inside diameter to the larger size without weakening the casting too much or would it break through the sidewall?
If it can be done then all one would have to do is make a new butterfly and reinstall it.
Old Apr 21, 2010 | 06:48 PM
Beaner's Avatar
If you want I can make a trip up to your area and you can have a look for yourself! tomorrow or just about any other day.
Old Apr 21, 2010 | 07:09 PM
Infinite's Avatar
you mean bore the 72?
its possible but any bigger and you'd need to port the flange on the intake manifold
and without any more mods the 72 is more than enough, look into injectors and a v8 maf first
Old Apr 21, 2010 | 07:23 PM
How about meeting halfway? That puts it around Burlington - Stoney Creek on the QEW. Do you know any good spot?
Tomorrow is fine.
I have been thinking of making my own catch can, there are a lot of DIY's on the net such as this one that looks neat.
http://www.pbase.com/rsrock/oil_catch_can
Old Apr 21, 2010 | 07:41 PM
Beaner's Avatar
Tomorrow is fine. As long as we meet before dark due to me not haveing any headlights at the moment...
Old Apr 21, 2010 | 07:43 PM
I'm talking about boring out the stock n/a from 68 to 74 mm to match the flange. Just wondering if it's possible.
Infinite's Avatar
the catch can is simple, plug the line on the maf elbow. run all 3 lines from the breather covers to the can. Im mounting mine near the brake master. Im not going to run it back to the intake because crankcase pressure will force everything into the can and i dont want and oil vapors going back into the intake tract. makes for cleaner air, more efficient combustion, etc.
im also deleting the air injection and the egr valve
Old Apr 21, 2010 | 07:44 PM
Infinite's Avatar
I know people have done it, but i purchased mine for 150 off of ebay from an 05 e55 amg, it even came with the rear superchager housing. Just swap the electronics and youre good to go. not worth it boring out the stock one. I like to have to stock parts incase i ever want to convert the car back and sell it
How about noon then. You say where and I'll be there.
Old Apr 21, 2010 | 07:54 PM
Beaner's Avatar
Ok noon, 315 Centennial Parkway North, Hamilton, ON L8E 2X3‎ Tim Hortons. I will be there In my crossfire with the stock throttlebody in hand!
Old Apr 21, 2010 | 08:05 PM
OK, I'll pm my cell# in case of trouble.
Old Apr 21, 2010 | 08:13 PM
Beaner's Avatar
Home depot is right across the street if you were considering about priceing out parts from that link
Old Apr 21, 2010 | 08:22 PM
Infinite's Avatar
those types of catchcans are good for one line pcv systems, we have a 3 line system that terminates into one large one.
You'd be better off with each line having its own route to a common can
Old Apr 21, 2010 | 10:03 PM
So you have no outlet from the can, what good is that?
Old Apr 22, 2010 | 03:35 PM
Xray's Avatar
NW sells a very nice catch can that installs easily and has all of the parts you need to do it.
Old Apr 22, 2010 | 03:52 PM
Infinite's Avatar
the can doesnt need an outlet, just a filter.
you dont need a vacuum source when you're venting the catch can to atmosphere
Old Apr 22, 2010 | 05:33 PM
Beaner's Avatar
What do you do with the hose that goes from the cover to the intake before the throttlebody then? If it is not hooked up you will throw an engine code.
This is not a honda, I have done that to honda's before and it works on that just fine but not the crossfire
Old Apr 22, 2010 | 08:27 PM
Infinite's Avatar
I dont see why you would throw a code, no sensors monitor the breather system
Old Apr 22, 2010 | 08:51 PM
Beaner's Avatar
if this hose is not connected it will throw an engine light
