Stick shift question
Old Oct 28, 2010 | 09:07 AM
tundrapounder's Avatar
Default Stick shift question
How much HP will the stock 6 speed stick trans hold up to.
Old Oct 28, 2010 | 10:34 AM
Jesus_Christler's Avatar
Default Re: Stick shift question
Couldn't find the forum thread that discusses max HP (as a side issue), but here are two good points
The Crossfire N/A is the highest horsepower Chrysler to use this six-speed manual (NSG-370), although it's used in the Jeep Wrangler and Liberty with 4.0 litre V-6 with more torque. The torque limit is 272 foot/lbs. More here.
Gotbroken lists the 2004 SLK 350 (which puts out 272 horses) being paired with a standard six speed transmission (no indication whether it's the NSG-370). I would probably go to 300 myself but no further. Even then. I would beef up the clutch as far as it would go, get the best fluid possible and pull fluid samples for testing by a reliable lab frequently. Also, limit the bad boy action as much as feasible
Old Oct 28, 2010 | 08:31 PM
progress's Avatar
As far as the clutch goes SPEC told me they could custom make me a stage 2 + clutch off the slk32o specs for agound $850. Just somthing to think about if you have not upgaded your clutch yet..
Old Oct 28, 2010 | 08:42 PM
Infinite's Avatar
spec already has an application for crossfires in their catalog
and they start at 1200, which is rape for a single disc oem replacement.
and spec makes shitty clutches to begin with
no one knows the torque limit of the 6 speeds, no one has gotten there yet
Old Nov 4, 2010 | 08:48 PM
huntsmcgee's Avatar
How much can the auto trans in the limited hold???
crossfireusa
Oct 28, 2015 12:03 AM
RED DOG
-C-I-C-C-I Discussion
Oct 8, 2015 09:28 AM
Big_Country
Sep 22, 2015 03:47 PM
rmcdaniel12
Sep 21, 2015 10:58 AM
jaesa
Sep 7, 2015 01:50 PM
