Crossfire takes longer to start then normal
Old Nov 18, 2010 | 04:22 PM
ri2300's Avatar
Default Crossfire takes longer to start then normal
My crossfire is taking longer to start then normal. It use to start as soon as I turned the key but now have to hold the key in the start position for a couple of seconds before it starts. I have no idea what good be causing this so any suggestions would be helpful.
Old Nov 18, 2010 | 04:32 PM
Default Re: Crossfire takes longer to start then normal
well, you shouldn't have to hold the key at all once turned...battery could be getting weak...electrical connections....just for kicks and giggles, next time you try to start the car...turn the key to start and let go...see what happens...
Old Nov 18, 2010 | 04:43 PM
ri2300's Avatar
tried and it just cuts back to off
Old Nov 18, 2010 | 04:53 PM
stop by a Auto Zone or similar place, and have them check the battery. The will put a "load" on the battery to see if it is up to specs. There are a lot of other things down the line that can cause this, but this is the easiest to test. They do this service for free. They will look at your battery connections as well. Best place to start....
Hard to start could relate to fuel, to electrical, many things, but you have to start somewhere...
Old Nov 18, 2010 | 04:56 PM
Crossfireone's Avatar
If it's a 6 speed you have to hold the key till it starts. Mabey I missed him mentioning it was auto?
Old Nov 18, 2010 | 05:10 PM
you are right...didn't think of that since I have autos......good catch...
Old Nov 22, 2010 | 03:23 AM
lacerdaschoon's Avatar
Sounds like your battery to me
Same thing started happening to me a several months ago i was getting long cranks to start the car for about a month and finaly it didnt start. Turned out to be the battery
I would start looking at that first
Old Nov 22, 2010 | 04:54 AM
antonio311's Avatar
My crossfire took a long cranking time to start when purchased new, & my other one started right up. I had the Fuel pump replaced & now it starts right up just like the other one. Check your Fuel pump. =)
Old Nov 22, 2010 | 05:48 AM
Eric's Avatar
try parking it at a angle with the front of the car going downhill overnight and then see if it starts faster or not.. if it dus it might just be the check valve in the filter went out and all you need is a new filter. after my fuel upgrades the new filter dusnt have a checkvalve so if i park with my car faceing uphill it takes time to get the fuel back to the engine
Frankenmerc
20
Dec 13, 2025 11:51 PM
backinblack
Aug 11, 2015 09:41 PM
BEATv1
Jul 16, 2015 09:40 AM
syfi
Jun 22, 2015 07:23 AM
MJPowers
Jun 8, 2015 02:34 AM
