Put HID fogs and did not turn on???
Old Dec 25, 2010 | 03:40 PM
srt6power's Avatar
Default Put HID fogs and did not turn on???
I put HiD fogs in they were 35wat yellow 3000k, they did not turn on .. What could be the problem
Old Dec 25, 2010 | 03:56 PM
SilverWolf's Avatar
Default Re: Put HID fogs and did not turn on???
You most likely need to reverse the power leads running to your ballasts. I know mine are that way.(HIDGate kits)
Old Dec 25, 2010 | 07:04 PM
srt6power's Avatar
I have ddm tuning kits, it's a plug a play, they just don't turn on idk
What watts are yours
Old Dec 26, 2010 | 12:07 AM
Plug and play they may be but you still have to wire them up properly as Silver Wolf says.
The two wires from the ballast that plug into the existing OEM plug (that used to go to the OEM bulbs) have to be wired to the correct positive and negative wires.
If you have connected the positive wire from the ballast to the negative wire on the plug the bulbs will not work.
Switch these two wires around.
Old Dec 26, 2010 | 02:15 AM
SilverWolf's Avatar
I have 35 watt kits. But it shouldn't matter. Did you check for a blown fuse? If it's blown, that's a sure fire tip off that the polarity is reversed.
Also, to clarify, when I hooked up my hid fogs, they did not work. I found the fuse to be blown. I replaced it and tried again. The fuse blew instantly. So I reversed the polarity going into the ballasts and replaced the fuse. Paydirt! They worked. But only if positive is connected to the negative side of the ballast and negative to the positive side. You get what I'm saying?
Let us know how it works out.
Old Dec 26, 2010 | 03:43 PM
srt6power's Avatar
Thanks for the help I had to swap the positive and negative... Working like a charm
Old Dec 26, 2010 | 04:29 PM
SilverWolf's Avatar
Glad to hear it!
xfClifford
Mar 3, 2021 04:52 PM
PNA
Nov 12, 2020 04:44 PM
Adrian_X
Nov 9, 2017 08:49 AM
gp1200x
Dec 6, 2015 12:59 PM
KwehCat
Jul 16, 2015 04:48 PM
