HID Headlamps
Old Mar 2, 2011 | 11:12 AM
TiredRetired's Avatar
Default HID Headlamps
I am planning on upgrading my lows to HID this summer. I researched quite a bit here as there are many old threads concerning this.
My question is, those of you that have done this before, what type of kits have you found to have the best luck with over the past few years. I'm looking for a good decent kit that doesn't break the bank.
Thanx in advance.
Tired
Old Mar 2, 2011 | 08:58 PM
Default Re: HID Headlamps
Maxcichon recommended to me this seller on ebay.
This is where I got mine from back in April 2009.
Max installed them at the Dragon GTG for me.
Chrysler Crossfire Xenon HID Conversion Kit 9006 h9 10
Old Mar 12, 2011 | 11:35 AM
magneticred's Avatar
I have the same lights as Valkryderguy. No problems at all.
Old Mar 12, 2011 | 12:47 PM
green-ghost's Avatar
A coworker got a set out of a toyota siennia van, 35 watts, low beams. They had a dual prong/gray cap that I imagine plugs into the stock wiring. If I can get them from him, would they work in my car? They are in good shape and clean
Old Mar 12, 2011 | 04:15 PM
The Crossfire uses H7 bulbs, the Sienna uses 9006 bulbs. I wouldn't bother.
Old Mar 12, 2011 | 08:00 PM
ok thanks on the info
Old Sep 7, 2011 | 09:53 AM
a7x6kse6's Avatar
The link no longer works, do you know the name of the seller?
Old Sep 7, 2011 | 10:19 AM
JHM2K's Avatar
I've heard really good things out of the Morimoto kits...
Old Sep 7, 2011 | 11:41 AM
I would search for Xentech kit. I have used several of them over the years and they are cheap and reliable. I would order 2 kits though, so if you do have a bulb or ballast go out, you will not be fumbling around trying to find an overpriced bulb or ballast locally (the kits are $35 shipped). If you find the right reseller, you will get a decent warranty.
Old Sep 7, 2011 | 12:20 PM
a7x6kse6's Avatar
I found a seller with good prices, free shipping and a 2 year warranty.
Here is the link to his store if any one else is interested: Hid-Technik
Old Sep 14, 2011 | 07:00 PM
Pat13's Avatar
Well i ordered from the same seller you linked and i am waiting for them to arrive, tommarow will be the 4 th day. I want them to come in already and just see how they look on the car. I'll update when they arrive and are installed
Old Sep 15, 2011 | 08:59 AM
Pat, do yourself a favor and either use a small magnet or a piece of string around the clips that hold the bulbs in. Many have dropped them into the housing - just trying to save you some grief on the install. And if you have a friend with 'carney' (small) hands, have them come over for the install
Old Sep 15, 2011 | 08:30 PM
Pat13's Avatar
Thanks for the tip ill give it a try, i heard those clipps were a pain. Sadly they diidnt come yet, tommorows another day
Old Sep 17, 2011 | 09:21 PM
Pat13's Avatar
Yeup i just recieved and installed my hid lights from the above link hid tech i believe his seller name is on ebay for $35. im have some problems with them because when i turn my car on i give it a minute and then turn them on. Some times one light turns on and not the other and vis versa. Some times neither of them come on and some time with luck they both come on, I also am alittle upset because they are blue. i did ask for 5k which is supposed to be the natural white light but they are blue so im sure there either 6k or 7k. Well sorry for the rant but im extremely frustrated, any suggestions?
xfireohio
Jul 20, 2020 12:03 AM
Adrian_X
Nov 9, 2017 08:49 AM
RojoGTO
Feb 6, 2016 11:14 AM
gp1200x
Dec 6, 2015 12:59 PM
AlbertFattal
Sep 24, 2015 05:03 AM
