Exterior Name Plates
Old Mar 15, 2011 | 02:22 PM
FUBU's Avatar
Default Exterior Name Plates
Hi,
Anyone got a good way of lining up the exterior name plates on the deck lid?
Take a photograph and somehow use a projector to mark out the ref points?
This is what the manual says:
EXTERIOR NAME PLATES
REMOVAL
REMOVAL - WITH DOUBLE SIDED TAPE
CAUTION: Use care when removing any component that is attached to the vehicles painted surface. Take
the necessary precautions to avoid paint damage while servicing the vehicle.
1. Mark the reference points before removing the name plate.
2. Using a heat gun, gently apply heat in a circular motion to loosen the adhesive bond.
3. Using a nonmetallic prying device, such as a plastic or wood trim stick, gently pry up at the corners and remove.
4. Clean off all traces of adhesive or double sided tape from the panel with a general purpose adhesive remover.
REMOVAL - WITH ADHESIVES
1. Mark the reference points before removing.
3. With a fingernail, lift up and peel away badging/tape from the panel, using a heat gun as you go.
4. Clean off all traces of adhesive from the panel(s) with a general purpose adhesive remover.
INSTALLATION
INSTALLATION - WITH DOUBLE SIDED TAPE
1. Prep the painted surface for the application of the new adhesive.
Note: Use a commercially available and approved Wax and Grease remover to prep the painted surface.
2. Align the badging to the previously marked reference points.
3. Install and press securely to assure full adhesive contact.
4. Clean away any marked reference points from the panel.
INSTALLATION - WITH ADHESIVES
2. Clean the panel surface with isopropyl alcohol.
3. Remove the paper carrier and align the badging/tape to the reference points or an adjacent panel.
4. Install and press securely, using a plastic spreader to eliminate all air bubbles.
5. Remove the top protective carrier.
6. Clean away any marked reference points.
Old Mar 15, 2011 | 03:19 PM
dinasrt's Avatar
Default Re: Exterior Name Plates
I establish reference points with "safe release painters tape". It is usually green or blue in color over here in the states.
Old Mar 15, 2011 | 05:27 PM
FUBU's Avatar
But I can't have any ref points as the decklid will be repainted..
maybe the projector bit maybe an idea. or markup with some paper...
If you buy new letters from the dealer, do you get some sort of a guide how ?
Old Mar 16, 2011 | 12:29 AM
dinasrt's Avatar
Make precise,accurate measurements from edges as well as space between letters before you remove letters/badge. Ask your body and fender man how he would do it.
Old Mar 16, 2011 | 02:04 AM
MikeR's Avatar
You could try cutting out a template that fits OVER the letters/badge and align it with the sides and bottom of the hatch.... you can add centerlines for each character on the template and measurements.....
Good luck....
Old Mar 16, 2011 | 03:16 PM
[quote=FUBU]Hi,
quote]
I did this layout when I was considering taking the letters off.
If this is what you want then modify it to suit the SRT and add the correct SRT sizes to the layout and repost for future use.
Old Mar 16, 2011 | 09:23 PM
dtinker's Avatar
You could make a stensil that fits to the lip of the hatch, or the projector sounds promising.
2004_
Jul 9, 2025 12:39 AM
55chevy
Jul 22, 2024 02:31 PM
eikon
Sep 9, 2019 10:16 PM
BlackJax-SRT
Sep 18, 2015 07:03 PM
BlackJax-SRT
Southeast Forum
Sep 17, 2015 03:03 PM
