foggy fog lamps - how to fix it
Old Jul 2, 2011 | 05:43 PM
Default foggy fog lamps - how to fix it
I noticed that both my fog lamps were very cloudy on the inside.
Here is how I fixed that :
1. remove the front wheel.
2. remove the little door in the front fender well.
3. unplug the fog lamp bulb.
4. using a T20 Torx, remove all 3 screws that mount the assembly.
5. there are 2 'bearing' points and an adjuster. By prying the bearing joints ( carefully )
and screwing the adjuster in/out, you will be able to release the bulb holder from
the light assembly and swivel the bulb mount around and out of the way.
6. using a thin piece of wood or plastic, clean the inside with a micro-fiber cloth.
7. place the rubber o-ring in the housing, and re-assemble the light socket to the housing.
8. adjust the screw ( also T20 BTW ) so the light socket is even on both sides with the housing ( pressing on the light socket helps to seat it )
9. put it all back in.
10. do the other side.
Old Jul 2, 2011 | 07:52 PM
Default Re: foggy fog lamps - how to fix it
I did a write up on this a while ago with pics. To get the o-ring properly seated to prevent moisture in the future, you need some silicone lubricant on the o-ring and it will pop right in correctly. It is possible to get the assembly back together with the o-ring not seated properly. Been there, done that.
Here are the pics I used: https://www.crossfireforum.org/galle...y.php/cat/2004
James
Old Jul 2, 2011 | 08:18 PM
Thanks - I did a search before submitting the post and didn't see yours, sorry.
Yours is a much better write-up.
Old Jul 2, 2011 | 09:26 PM
No problem, I am sure with both our combined posts, they will help out others in the future. James
eikon
Sep 9, 2019 10:16 PM
Mike OD
Sep 23, 2016 07:00 AM
Steven 4190
Nov 25, 2015 10:12 AM
crossfireE
Oct 2, 2015 01:40 AM
maxcichon
Sep 4, 2015 12:50 PM
