HID Signal conversion
Old Oct 23, 2011 | 08:08 PM
turbomar's Avatar
Default HID Signal conversion
Just completed my LED signal light conversion. My intention was to have the white lens effect when not on and have the instant on, instant off effect. It just looks cool and up with the times.
2 load resistors are required per side. However, to keep the resistors out of sight, I have mounted both resistors on the taillight assy.
Correction: The thread title should have read: LED signal conversion
Old Oct 23, 2011 | 08:17 PM
MikeR's Avatar
Default Re: HID Signal conversion
I am sure you are aware that those load resistors get VERY hot in use.... since they are on the turn signals it will likely not be an issue, but I would check them a few times after using the signals and ensure that they are not going to damage your light assembly.....
I used them on my license plate LED mod and mounted the resistors on the inside of the hatch frame so they would have heat sinks and not be an issue......
Old Oct 23, 2011 | 08:24 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Nice job....very well done. Looks like you used GTF wiring?
Old Oct 23, 2011 | 09:05 PM
turbomar's Avatar
They do get hot allright. However, they are not mounted on the light assy. See last pic
I have replaced most of the lighting in and outside the car with LED's. I reasoned that the "light out indicator system is unable to tell me when an LED is out, I have opted to cancel it and therefore avoid installing a load resistor for every converted bulb. Back to the good ol circle check!
Old Oct 23, 2011 | 09:07 PM
turbomar's Avatar
Thanks Sparkie. Yes, the GTF wiring came with the load resistors.
Old Oct 23, 2011 | 09:23 PM
As mentioned by MikeR those things must run hot because GTF is rated for 125C.
Old Oct 23, 2011 | 09:58 PM
arejohn's Avatar
What controls the bulb out indicator. Could it be modified to be compatible with LEDs?
Old Oct 23, 2011 | 10:39 PM
arejohn's Avatar
I looked at the wiring diagrams and see the bulb out lamp is controlled by the Illumination Control Module and don't think messin with that is a practical solution. But what if the lamp wire between the ICM and instruments is cut?
Old Oct 24, 2011 | 06:47 AM
maxcichon's Avatar
And the highest temp rating I have found for CABLE TIES is 100 C.
http://www.mcmaster.com/#zip-ties/=emnhav
Old Oct 24, 2011 | 02:35 PM
turbomar's Avatar
McMaster-Carr
I get your point. Will have to get the infrared thermometer out.
xfireohio
Jul 20, 2020 12:03 AM
gp1200x
Dec 6, 2015 12:59 PM
AlbertFattal
Sep 24, 2015 05:03 AM
tritongreen
Sep 18, 2015 07:32 AM
maxcichon
Sep 4, 2015 12:50 PM
