Has anyone ever found the reason for the 5th "O" ring in some of the filter kits?
... Deleted ...
... Deleted ...
I found that the extra O ring fit the dip stick just fine .....
I don't know if that is the intended purpose, but it sure fits tighter now than it did before.
There are 4 different sized o-rings used on the M112/M113 filter bayonets while there are only 2 sizes that are used on the M272/M273's. On the M112/M113's, which is what our cars have, the largest o-ring goes at the very top (in the second groove down from the top) to seal the filter cap the the filter housing, the next one smaller goes just under the base of the filter, the next smaller after that goes around about an inch from the end of the bayonet and the smallest goes at the very tip. There are two of the second largest ones because while the same filter is used for all 4 motors, the bayonets are different as can be seen below and the M272/M273's use the largest one and then both of the next size smaller and do not use other two.
M112/M113
M272/M273
M112/M113
M272/M273
... Deleted ...
... Deleted ...
... Deleted ...
... Deleted ...
dedwards0323
Feb 8, 2014 11:00 PM
315er
Sep 24, 2010 07:42 PM
v8valiant
Dec 21, 2008 06:32 PM
