Mystery Re-Start
Old Jun 21, 2013 | 05:04 PM
bahston's Avatar
Default Mystery Re-Start. PLEASE READ! NEED HELP WITH...
Hi Guys. I have an '05 Limited Conv that won't start unless I put the key in ignition in the ON position and (2nd) key in the drivers side door in the lock position and hold it there for approx thirty seconds and then the ECM? RCM? Skreem? clicks and RESETS( something re security?) Then I turn the ignition switch to the off position( key in door is out) and then to the start position and the car will start. Once in awhile I need to take the battery cables off and then go through the same sequence, and whala, it starts!
No check engine or codes show!
Battery checks!
Key FOB's are working( lock, unlock, start etc)!
Checked fuses!
It's seems to be something that is RESETTING! Dreading having to take it to a dealer!
What is it?
Thanks!
bahston
Last edited by bahston; Jun 21, 2013 at 08:07 PM. Reason: Better Header re description: NEED HELP WITH!
northwest_crossfire
May 30, 2016 05:19 PM
Steven 4190
Nov 25, 2015 10:12 AM
StanTheEdge
Sep 2, 2015 12:05 AM
Steven 4190
Aug 15, 2015 10:35 PM
SuperD500
Jul 23, 2015 02:53 PM
