Washer pump
Old Aug 18, 2013 | 06:18 PM
stefanwelsh's Avatar
Default Washer pump
I have a 2004 crossfire coupe.
when I go to spray the washer fluid the fluid does not come out. I have plenty of fluid and the wipers work still.
Is this the washer fluid pump that has malfunctioned or something else?
Old Aug 18, 2013 | 06:23 PM
Default Re: Waher pump
Either that, or a clogged / loose hose or a blown fuse #32
BTW: to gain access to the tank/pump, you must remove the passenger side front wheel, then drop down the plastic fender liner.
Old Aug 18, 2013 | 06:27 PM
If the fuse was blown the wipers wouldn't move right?
Old Aug 18, 2013 | 06:34 PM
I think fuse # 20 does the wiper motor itself, but you may be right since fuse # 32 supplies the voltage to tell the BCM to run the wiper motor.
Old Sep 4, 2013 | 09:32 AM
jwheeler's Avatar
Default Re: Washer pump
I have the same issue with my 04 Crossfire but I haven't had time to remove the fender liner. Were you able to resolve your problem?
Billy22Bob
Sep 28, 2015 08:08 PM
Sep 26, 2015 10:21 PM
Billy22Bob
Sep 26, 2015 10:16 PM
Selbyl
Sep 26, 2015 04:15 AM
tritongreen
Sep 18, 2015 07:32 AM
