tire pressure monitor system light is on
Old Oct 7, 2004 | 09:00 AM
j monaco's Avatar
Default tire pressure monitor system light is on
First semi chilly nights in NY. and the tpm light is on.Tire pressure is only off 1 lb. Any suggestions ? Are the sensors that sensitive? Thanks Jim
Old Oct 7, 2004 | 09:35 AM
TSaxMan113's Avatar
Default
That one pound could trigger the light. I haven't seen a spec sheet on the sensor, so I don't know it's exact activation point. The light should, however, go out after the tires warm up a bit...
Old Oct 7, 2004 | 10:11 AM
C_Plunkett's Avatar
Default
The service manual says the light should come on at 26 lbs or if the pressure changes by more than 1 pound between subsequent readings. I guess that might trigger it if it has lost a little over a pound while parked.
Old Oct 7, 2004 | 03:38 PM
willie's Avatar
Default
last winter my light would come on in the mornings but by the time I had driven to work 25 miles it would turn itself off
Old Oct 7, 2004 | 04:37 PM
blackal's Avatar
Default
My light came on the other day. I was 2# low on the right front.
Old Oct 7, 2004 | 09:43 PM
John Webster's Avatar
Default
Mine went on with 28-29 psi in the tires. I suspect its set at 28 psi.
It's another of those devices that you wouldn't order if it was optional but learn to like when you've got it.
Old Oct 7, 2004 | 10:16 PM
Dan Root's Avatar
Banned
Default
I have yet to see a light go on in 14k miles .
Old Oct 7, 2004 | 10:28 PM
X-fired's Avatar
Default
Ditto. It cooled down and mine came at around 30#.
Old Oct 8, 2004 | 12:02 PM
NJspeed69's Avatar
Default
I suspect a lot of people will have their warning lights come on as it gets colder everywhere.. colder = lower PSI. And it will be worst for those who last checked their PSI on a hot day during the summer.
Old Oct 8, 2004 | 12:11 PM
mbepic's Avatar
Default
When my light first came on, I thought it may have been false reading but upon inspecting tires, I found that I had picked up a nail and had very slow leak. I've since had that fixed but since it's been getting colder in the morning, the light has been coming on again. Adding a couple of pounds to all four seems to have fixed that. Car still rides beautifully.
Old Oct 18, 2004 | 11:03 PM
Mouse Legend's Avatar
Default Re: tire pressure monitor system light is on
Mine has been coming on for a couple weeks for the first 10 miles or so each day. It is not THAT cold here in the mornings, (high 50's). I have one stem cap missing and that is the tire that always needs a tiny bit of air. Time for its first oil change so I will pick one up at the dealerand ask them about it.
Old Oct 19, 2004 | 05:14 AM
mbepic's Avatar
Interesting that one tire actually needs air. I would say you might have a slow leak somewhere. Possibly, if the valve cap is missing, someone might have loosened the valve stem. I would check that.
Normally, if the monitor light is coming on in the morning, first thing, you can usually cure that by adding 1-2 lbs. in each of the four tires. Sounds like you have a different prob.
Kodebuster
Nov 5, 2020 04:06 PM
Bifftws
Racing
Jul 28, 2015 05:31 PM
axnguyen
Jul 21, 2015 11:41 AM
bdh
Jul 9, 2015 09:40 AM
Blackout317
Jul 7, 2015 08:38 PM
