Crossfires - Interference or Non-Interfernce engines ??
Old Oct 12, 2013 | 11:27 PM
Default Crossfires - Interference or Non-Interfernce engines ??
A little research online explains the difference between Interference or Non-Interference engines and how damage will occur when a timing chain breaks in an Interference engine.
Just wondered what engine our cars have after a conversation with a friend tonight.
Do we have "Interference" engines or "Non-Interference" engines ??
Also any recommend interval for replacing our timing chain ?
Just wondering
Gary
Old Oct 12, 2013 | 11:35 PM
Default re: Crossfires - Interference or Non-Interfernce engines ??
I believe we have non interference engines.
We have good compensators on our CV6 engines so, unless one is sloppy about oil changes or drives like me, 80K miles is the soonest you should worry about the timing chain. Actually 120K is about right.
Old Oct 13, 2013 | 09:15 AM
from : https://mercedessource.com/problems/...ain-and-guides
Problem & Solution
Common among these chassis:
W107 W108 W109 W110 W111 W112 Sedan W111 W112 Coupe W113 W114 W115 W116 W123 W124 W126 W201 Classic Sedans Ponton
WARNING: Timing chain failure is the NO. 1 cause of catastrophic engine failure in these old engines. If it lets go the valves will hit the pistons. If it comes off at high speed, the pistons can be damaged and the camshaft can be driven right out through the valve cover!
CAUSES: There are a number of reasons for excessive chain stretch / chain failure.
Age: Just imagine what is happening to that chain as it spins in your engine at 4000 rpm. Timing is everything and the chain is the key timekeeper. At some point they just wear out no matter what you do to maintain. If you have an engine with a chain that has already gone 150,000 miles replace it for peace of mind and financial security.
Lack of Service: Given good oil change intervals, timing chains can last from 120,000 to 200,000 miles before requiring replacement. I have seen lack of oil changes cause them to stretch beyond useful life within 80,000 miles.
ingsoc39
Nov 25, 2019 05:44 PM
rayth
41
Jul 31, 2019 04:02 PM
roland1226
Feb 26, 2019 10:19 PM
GraphiteGhost
Jun 12, 2015 12:04 PM
MJPowers
Jun 8, 2015 02:34 AM
