Roadster Subwoofer Trunk Design
Old Apr 22, 2014 | 09:33 PM
Tampa's Avatar
Default Roadster Subwoofer Trunk Design
Hello all. I recently purchased a 2005 Roadster Limited. I am bit of a audio fan and the old stock infinity subs are shot.
I have drafted a design for the roadster for a 1.75 cubic foot enclosure for a single upward facing 12. The box fits completely under the top when stowed so as to not restrict the use of the convertible. I searched the forum a little but couldn't find a thread with recommendations for grounding location or a tap for a remote (acc on) wire. If anyone has ideas or recommendations, please shout out. Thanks
Also, if anyone wants the schematic for the enclosure, I am happy to share.
Old Apr 22, 2014 | 11:52 PM
MoparFreak69's Avatar
Default Re: Roadster Subwoofer Trunk Design
I used a truck box with a 10 in it for my roadster. Works good, although the sub barely fits in the box, and its a little tight squeeze under the divider. It could stand to be wider and a bit shorter to physically fit underneath the divider better, but it was something I already had and fit when thrown in so I can't complain too bad.
As far as powering the amp. I ran a ground wire from the amp to the obvious 'frame rail' tube and connected it with an eye and a self tapping screw. I ran a new power wire theough the passenger compartment straight to the battery. For the remote turn on wire I connected it to my aftermarket head unit. If you are retaining the stock head unit then you can tap into the keyed power wire at the radio connector, but I can't imagine why you would keep the stock head unit to power a separate sub.
Pics of your box installed in the trunk would be good.
waldig
Jul 31, 2017 09:46 AM
mobilefitt
Jul 28, 2015 03:45 PM
pioneer4x4
Jul 27, 2015 02:04 PM
waldig
Jul 20, 2015 08:10 AM
tom2112
Jul 12, 2015 04:41 PM
