Rewiring AMP for 4 channels / RCA plugs, should I use rear or sub pre outs?
Old May 7, 2014 | 12:53 AM
tageier's Avatar
Default Rewiring AMP for 4 channels / RCA plugs, should I use rear or sub pre outs?
hi everyone,
finishing up my install of my Alpine CDE-HD149BT tomorrow morning/afternoon. I wasn't going to rewire my amp until i realized how much more sense it would make and how easy it really seems.
My Alpine head unit has 4V pre outs for front, rear, and subwoofer. I am wondering since the rear speakers are subwoofers, should I use the pre outs for rear or subwoofer? it seems like subwoofer would be the logical choice, but nothing on our cars is ever logical would they both produce the same sound, does it matter?
Old May 7, 2014 | 11:29 AM
MoparFreak69's Avatar
Default Re: Rewiring AMP for 4 channels / RCA plugs, should I use rear or sub pre outs?
Typically the subwoofer pre-outs do not carry any high frequency sounds. My Kenwood allows me to choose the frequency cutoff, i imagine your deck probably does too. It is fine to wire it as you suggested. Just be aware that you might not get a lot of sound out of the subs, I don't, but then again I really never did. They work, I can feel the vibrations on the back wall, I just can't really hear much from them.
Old May 7, 2014 | 12:55 PM
Airscape's Avatar
All depends on your unit. Some will let you set up crossover for front and rear channels independently, others won't. (My alpine did not) To be safe I would just use the sub outs as they should always have their own crossover settings. Also the stock amp has its own built in crossover for the subs so even if you hook the rears to the rear outs you will not hear anything higher frequency than the built in crossover. (Not sure what the cut off is)
My setup with an alpine
Front pre-outs directly to amp front input
Sub pre-outs directly to amp sub inputs
I can't remember the exact settings but I think I had the front crossover set to >120 and bumped treble up a couple tics too which gets rid of a lot of the door bass (and rattle) and cleans up the highs. I just left the sub crossover as is because the amp is doing it anyway but I increased the sub volume to almost max (note my head unit was only 2V output) which supplied the bump and lows. Sound is much better than stock but max volume is lower because of the 2V (at max volume sound levels were right before it starts to get distorted or rattle so it worked out) but I do wish it could go a liiiitle higher as my source is majority iPod and levels on some recordings are a little lower than others.
tom2112
Jul 5, 2015 09:20 PM
rmcdaniel12
Jun 10, 2015 03:51 PM
racingagent
Jun 8, 2015 07:29 PM
eastside08
Jun 7, 2015 07:21 PM
WindRestrictor
Jun 1, 2015 02:31 PM
