RCM Module relay needed
Old Oct 9, 2015 | 06:52 AM
Peg's Avatar
Peg
Thumbs down RCM Module relay needed
Hi People,
I think I have found the intermittent P0410 error code I have been experiencing over the past couple of weeks it looks like the air pump relay is burnt and pitted (see photo).
Dose anyone know were I can get one from here in the UK.
Cheers,
Peg.
Old Oct 9, 2015 | 06:22 PM
Default Re: RCM Module relay needed
Originally Posted by Peg
Hi People,
Cheers,
Peg.
If you cannot get a relay cheap enough you should consider a used RCM, It may work out cheaper, naturally you want one with an unburnt relay. If it too is burnt you will have extra spares to swap into your original relay.
It does not have to be the same number as the one you have, Turbomar used a different part and it works. just change the lower fuses to match you OEM one.
Turbomar used this part, RCM #A 210 540 00 72
This is what I get on US eBay for this item. CLICK
When I use that number on the UK eBay site I get different looking parts.
Power Sedan
Nov 8, 2015 01:52 PM
nickwe21
Oct 9, 2015 12:45 PM
tritongreen
Oct 8, 2015 02:39 PM
Oct 8, 2015 01:17 PM
tritongreen
Sep 18, 2015 07:32 AM
