New addition to my car:
Old Feb 12, 2005 | 04:54 AM
pnsji's Avatar
Default New addition to my car:
Brabus shift **** and door sills:
New wheels, Lorinser LM6 19" front and back
What do you guys think?
Old Feb 12, 2005 | 05:40 AM
x'ed's Avatar
Default Re: New addition to my car:
wow, those rims are amazing, what type and how much and what size?
Old Feb 12, 2005 | 12:11 PM
Dan Root's Avatar
Banned
I like the **** but why the sill covers ? And I thought those wheels would look nice on the XFire ,Isaw them at Eurorev.Like the finish .Did you have to space them ?
Old Feb 12, 2005 | 03:34 PM
Bob G's Avatar
Very nice!!
Old Feb 12, 2005 | 07:31 PM
Epyon
Guest
Posts: n/a
nice rims, but sorta a identity crisis.
mercedes rims on a chrysler.
Old Feb 12, 2005 | 10:55 PM
Dan Root's Avatar
Banned
Chrysler Emblems on a Benz ?
Old Feb 12, 2005 | 11:10 PM
andrew's Avatar
-C-I-C-C-I Associate Member
that looks nice! what size?
https://www.crossfireforum.org/galle...sort/1/cat/500
what kind of camera are you using? great detail.
Old Feb 13, 2005 | 03:46 AM
pnsji's Avatar
Thanks for the comments!
Specs:
19x8.5" 235/35/19
19x9.5" 255/35/19 -> I should have gone with 265/30/19
It was $1200 for the wheels.
I like the door sills. I will continue to have full brabus stuffs for the inside
Old Feb 13, 2005 | 03:50 AM
pnsji's Avatar
Cool Re: New addition to my car:
Oh BTW, I was using my old Canon G1.
Old Feb 13, 2005 | 05:52 AM
KyleJWink
Guest
Posts: n/a
i just crapped my pants
Old Feb 13, 2005 | 12:26 PM
Dan Root's Avatar
Banned
Specs:
19x8.5" 235/35/19
Did you have to use spacers .Do you know how much they weight ?
Old Feb 13, 2005 | 03:34 PM
pnsji's Avatar
I have to use 20mm spacers at the back. Don't know about the weight.
Old Feb 13, 2005 | 04:47 PM
saldous's Avatar
Are those rims a mercedes part as they have Merc caps on them? They look sweet btw.
Old Feb 13, 2005 | 11:21 PM
pnsji's Avatar
More shots, daytime shots:
Saldous, They are Lorinser style wheels, not OEM Mercedes wheels.
Old Feb 14, 2005 | 01:07 AM
Dan Root's Avatar
Banned
Did the your car drive any differently ?besides looking great?
Old Feb 14, 2005 | 01:51 AM
pnsji's Avatar
New wheels and tires = ride the same
Still looking for 3.2 AMG charger.
Old Feb 14, 2005 | 11:33 AM
Dan Root's Avatar
Banned
I found out the other day a Benz V-8 will fit easily.Check out the thread on a Simple Mod V-8 airbox,also you could probably buy a V-8 cheaper.
Old Feb 14, 2005 | 03:27 PM
pnsji's Avatar
Yes the engine will fit. The problem is the wiring harness. My friend installed a 5.5 AMG into a C43 to make a C55. Everything is a breeze because the share the same wiring harness.
Crossfire/R170 SLK is still using the old wiring harness. You could tell by looking at how the ignition works:
R170 SLK/Crossfire -> you have to hold the key until the car start
Newer benz with V8 -> you don't have to hold it. The car will start by itself.
Having worked on a lot of Mercedes and dealing with their wiring harness, sensor, electronics, I know that this is no simple task.
As far as power, one of my friends has an SLK32 and After driving it(more like being inside a slingshot), I decided that it has enough power that I could handle. Any faster than that, not sure if that is good for me
Good luck with your search on V8 engine.
Old Feb 14, 2005 | 03:44 PM
christo76's Avatar
I don't have to hold my key until the start. Just the initial twist and immediate release and it starts on its own. Unless I am totally misunderstanding what you mean.
Old Feb 14, 2005 | 05:35 PM
pnsji's Avatar
Can you verify this? Maybe the start is really quick so the moment you twist it, it start right away. Let's say if the start takes 1 seconds, you would have to hold it.
Our key(the flip one) need to hold. The newer Mercedes has smart key(no metal part seen) can have the auto start.
