No FM reception on factory receiver
Old Feb 25, 2016 | 03:39 PM
Istrix's Avatar
Default No FM reception on factory receiver
Here's a fun new challenge:
After garaging my 2004 with the stock stereo (no GPS) for about a month the stereo is not picking up FM. All I get is static, and if I max out the volume I can just barely hear stations under the static. CD player works just fine. I'm guessing maybe an antenna issue maybe? Anyone seen this before?
Old Feb 25, 2016 | 03:48 PM
Default Re: No FM reception on factory receiver
Yep. Rats or squirrels ate your antenna cable
Old Feb 25, 2016 | 06:56 PM
Maybe that is a too simple answer.
If I recall correctly the cable is 99% inside the car, it is outside the car only in the rubber conduit between the body and the rear hatch.
Old Feb 26, 2016 | 07:52 AM
Simple answers come from simple people like me.
Maybe the critter(s) got in the car ?
Antenna termites ?
Old Feb 26, 2016 | 11:04 AM
Antenna termites ?
I am sure that the cable is mostly wrapped up in a major wiring harness, so in that area it would be difficult to separate it and chew it alone.
Surely not termites, most likely ants.
Old Mar 5, 2016 | 01:56 PM
Istrix's Avatar
Termites? Ants? Are you guys being serious or just messing with me?
I've never taken apart the stereo system on this car and I'm mostly curious on thoughts on where to start tearing this thing apart to find the problem. I can't imagine I'm the only person to run across this.
Old Mar 5, 2016 | 03:11 PM
No, we are not serious.
The coupe has the antenna in the rear glass, the roadster has a stick-up antenna.
Old May 4, 2016 | 11:10 AM
Istrix's Avatar
Well in lieu of calling pest control I bought a new stereo deck, wired up the antenna adapter and, boom, FM is back. I've now noticed that I've got nothing but faint static and almost non existent bass thumping from the back speakers. I plugged the old deck back in to realize the same issue.
What fresh hell is this?
Old May 4, 2016 | 11:17 AM
All depends on how you wired in the aftermarket head unit.
MOST of them have 2 volt preamp outputs, this WILL NOTdrive the OEM Infinity amplifier enough to get good sub woofer, or door speaker volume, you must use the head unit's speaker out wires to drive the amplifier.
If you got lucky and your new unit has 4 volt preamp outputs, then you should be able to use them.
Old May 5, 2016 | 10:16 AM
Istrix's Avatar
I did some reading ahead of time and bought a unit with 4amp outs. I guess I'll just have to put new subs in the back.
Old May 5, 2016 | 11:29 AM
FM back, nothing but faint static? What does that mean?
FM with static or just static?
Old May 5, 2016 | 06:37 PM
Istrix's Avatar
They're giving a tiny bit of bass thump and super faint audio from any source (FM is back in the front!)
I'm fairly certain the 10 year old factory subs are shot, I'm just going to replace them.
pioneer4x4
Feb 23, 2020 06:45 PM
bodhijames
May 6, 2016 12:32 AM
RED DOG
Mar 20, 2016 08:04 AM
beachguy
Mar 3, 2016 11:40 PM
bodhijames
Feb 29, 2016 09:26 AM
