Beep noise only when I drive agressively
Old Jun 10, 2016 | 11:57 AM
Rcking323's Avatar
Default Beep noise only when I drive agressively
Hey guys, so I have a weird one for you all...
When I drive the crossfire (n/a, not srt6) "spiritedly" I'll get this load beep noise coming from somewhere in the car, usually only once of twice a drive. When It happens I don't see or feel any ill effects, but I usually get off the gas pretty quick out of surprise (its rather loud).
It usually happens if I've downshifted into a corner and kept the RPM's high and gotten back on the gas out of the corner. It usually beeps whenever I have more than ~80% throttle for a few seconds, then it goes away all together.
I've looked and looked, but I don't even seen this mentioned before.
Anyone else have this happen?
I just want to make sure I'm not going to blow up something!
Thanks guys!
Old Jun 10, 2016 | 04:07 PM
Default Re: Beep noise only when I drive agressively
Try unplugging the alarm module just for grins ......
Old Jun 10, 2016 | 10:41 PM
Have you ruled out the traction control system? I can get mine to pop off doing that or a similar maneuver. But then my rear tires are almost like racing slicks.
You will see it on the Speedo where it lights up when activated.
Old Jun 11, 2016 | 10:15 AM
Rcking323's Avatar
That module is actually dead... hahaha. My alarm went off the other night and i realized the loudest sound it would make is the slightest chirp
As for the traction control, I've gotten the beep with it on or off and both ways i always check the dash for any kind of warning light and see nothing
Old Jun 12, 2016 | 09:16 AM
maxcichon's Avatar
Search for "Cricket on Crack".
