headlight housing removal
Old Mar 28, 2017 | 10:03 AM
csteve0355's Avatar
Default headlight housing removal
Where is the best location to get to the two lower bolts in order to remove the housing? Does the bumper need to be loosened to get the housing out?
Old Mar 28, 2017 | 10:17 AM
Default Re: headlight housing removal
You can remove the wheel and go though the little door in the splash shield with a 10 mm on a long extension, or access the outside one through the marker lamp hole and the inside one by feel from the back of the headlight.
It helps to remove the top bolt in the bumper cover by the headlight and lift the cover a bit to persuade the unit out.
I usually remove the lower screw-in adjusters on the unit to provide a bit more clearance, but some say this is not necessary.
Old Mar 28, 2017 | 10:30 AM
If you remove the grille, you can get to the inner lower very easy.
Old Mar 28, 2017 | 07:46 PM
csteve0355's Avatar
Noted, and thanks for the tips.
