Car problems
Old Apr 1, 2017 | 06:31 PM
brauliohoggan's Avatar
Default Car problems
So I just changed my crankshaft position sensor and that didn't do anything. My car still shuts off while I'm driving and I have no idea what's causing it. It's been doing this for about a month now and it's very annoying.
Old Apr 1, 2017 | 06:45 PM
S8MS-01904's Avatar
Default Re: Car problems
Welcome.
We are here to help.
Need a bit more info like: random quitting while driving or "mystery no start"? Cold or fully warmed up? Was the replacement CPS a Bosch brand?
Has you looked at the RCM?
Old Apr 1, 2017 | 06:53 PM
Yes, It shuts off while I'm driving. And it doesn't take much driving for it to shut off. I'll be driving then the car will kick and then all the lights on the dash come on and the car engine shuts off. The radio and everything still works just the engine won't start for a while. I replaced my first cps sometime in the last months of last year and then two weeks ago my car randomly shut off while driving. But my car had been having trouble starting prior to this, just not shutting off while driving. Then I changed it out again today and I took if for a drive and the same thing happened. It gave a kick of some sort, all the warning lights on the dash came on and it shut off.
Old Apr 1, 2017 | 06:55 PM
Originally Posted by S8MS-01904
Welcome.
fully warmed up, the replacement was and eom part but I ordered a Bosch one today and it should be coming In Monday. And what's the RCM?
Old Apr 1, 2017 | 07:05 PM
S8MS-01904's Avatar
RCM = Relay Control Module. Near the battery, usually an issue with mystery no start.
file:///C:/Users/Acer/Downloads/Relay%20Replacement%20In%20RCM.pdf
Old Apr 1, 2017 | 07:08 PM
S8MS-01904's Avatar
Search the How to's for RCM, mine was OK, but many are not.
Old Apr 1, 2017 | 07:25 PM
Correct me if I'm wrong but I believe a bad RCM can also cause the symptoms in this case.
Old Apr 1, 2017 | 07:26 PM
Originally Posted by brauliohoggan
this is what I'm working with
Old Apr 1, 2017 | 07:43 PM
S8MS-01904's Avatar
That doesn't look bad, how are the relay contact points?
Old Apr 1, 2017 | 08:00 PM
Is this it?
Old Apr 1, 2017 | 08:07 PM
S8MS-01904's Avatar
Clean! .
Old Apr 1, 2017 | 08:10 PM
S8MS-01904's Avatar
Looks more like another CPS gone bad. Which I can not explain (no moving parts) - I'm a Mechanical Engineer.
Old Apr 1, 2017 | 08:11 PM
KDW4Him's Avatar
I can see the rings around the posts in the three upper left solder pads, resolder for sure. When you can see discoloration rings it indicates stress.
Old Apr 1, 2017 | 08:34 PM
Will try that tomorrow and get back at you guys, thanks!
Old Apr 2, 2017 | 01:55 AM
JSK's Avatar
JSK
I had the same symptoms, replaced the CPS to no avail. Pulled the RCM, sent it tighed1 in Sierra Vista for repair and haven't had a problem since.
Old Apr 2, 2017 | 02:01 AM
Can I have some more info on where you sent it and what they did to the RCM?
Old Apr 2, 2017 | 02:10 AM
JSK's Avatar
JSK
Go to the "TSB and how to section" look at posts 1047-1049 in the current thread "How to repair the relay control modole" for all the info you need.
Old Apr 2, 2017 | 02:15 AM
Do I find this on a website or YouTube?
Old Apr 2, 2017 | 02:41 AM
JSK's Avatar
JSK
In the technical section of this forum.
