Conv. Top won't go down?
Old Jun 12, 2017 | 07:48 AM
kstewart's Avatar
Default Conv. Top won't go down?
2007 Crossfire the top on conversion. does not work. Check fuze is ok what next? I am just lost.
Old Jun 12, 2017 | 09:49 AM
Default Re: Conv. Top won't go down?
Check the trunk divider, must be in upright position and must be closing the switch on the driver's side where the bar hooks in.
Old Jun 12, 2017 | 12:47 PM
kstewart's Avatar
Will do and let you know if this works Thank you
Old Jun 15, 2017 | 07:59 PM
kstewart's Avatar
I did what you said to do. Still the top won't go down. When I push the button to operate the top it beeps and that all. I got the flap in the trunk hook as you said and that not it. Now what???
Old Jun 16, 2017 | 04:24 PM
There is a switch mounted to the top frame just above the passengers ear. Sometimes I have to pop the top and juggle that switch a little bit and then it works. I am assuming a bad connection.
Old Jun 16, 2017 | 08:05 PM
Yes, this switch has a plastic slider that can get persnickety.
( that's a technical term )
Old Jun 16, 2017 | 10:57 PM
deltacrossfirebob's Avatar
Bum
Bum
Following as I am still having my own problems
Thanks
Old Jun 17, 2017 | 08:40 AM
cobra1951f's Avatar
I had and issue similar, I put the top down Manuel and and it reset what ever was out of sink and has operated properly every since!!
Old Jun 17, 2017 | 09:34 AM
Shamrock's Avatar
Do the windows lower when you turn the "D" handle to release the top?
